SPL Dynamics Z2X-820 Car Audio Amplifier Logo
Posted on Sep 16, 2012
What can a 800 watts amp play - SPL Dynamics Z2X-820 Car Audio Amplifier
I'm new to the Car Audio seen.I just bought four 6x9's.Now I need a good Amp to push all four of them.Here's what I have.Sony XS-R6945 4 Way 6x9" 800 watt Full Range Car Stereo Speakers Power...
Look for a 4-channel amp that pushes 50 watts RMS @ 4 ohm.
Make sure the amp is CEA-2006 compliant.
Ignore peak or max watts as these are arbitrary numbers.
More info here - sparky3489.webs.com
My 800 watt powered mixer was working fine until a keyboardist plugged in his keys and amp. The sound would fade out. When it was unplugged, it worked fine. Later that even, another DJ with an 800-watt...
All sound equipment has to operate without overloads in any given place. The power source should always be examined at commercial gigs and worked out with other performers along with management. The only fix is to do these checks up front and make safe arrangements.
Mar 18, 2013 • Music
2answers
Can i use a 300 watt amp for 2, 800 watt woofers
yes, but you would not get the same performance as you would if you gave them the suggested power. I have found that it is always better to use a more powerful amp than your subs are rated for (as long as it is clean, high quality, low distortion power). I have had the best luck with name brand amps (kicker,rockford fosgate,phoenix gold,etc...). I hope this will be helpful to you.
So I have the first kickers that came out the 15 will a 800 watt amp push um without eather blowin out
If you are referring to the Kicker L5 solo-baric subwoofer, then an 800 watt peak amp will not blow even one of those subs. The L5 is capable of handling 1000 watts peak and 500 wrms. An 800 watt peak amp will usually have around 400 wrms. Underpowering the subwoofer will not hurt the amp or the sub(s).
When I connect my 2nd sub, the amp blows fuses. Each sub plays fine individually.
Does your fuse blow when volume turned up, or does it blow straight away when turned on? What watt is your subs and amp?
I have 3500 watts of subs total of 1100 rms what size amp should
Make shure your running thick guage wire like 2-0 guage wire to get correct power to it also and check on amp the ohm's it can handle to make shure your not running to makny ohms.
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Audio bahn 1205n
sounds like your over working your amp 800 watt on a 2000 watt sub. might wanna upgrade your amp
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
My amp makes a constant tone
its says 800 watt and you say 20 watt bass amp?? Is this for a car or a guitar??
Top SPL Dynamics Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a SPL Dynamics Car Audio and Video Expert? Answer questions, earn points and help others
