I turnd the key and every thing went out (no power ) the battery was bone dry so we added water and jumpstarted the van OK good i drove home 1hr. drive, turnd off the van and tried to start it and it did not work. Went to buy a new battery put it in and nothing works yet the battery is fully charged. i don't understand..........
If it works jumping it then the starter is fine. check fusible links to see if one is blown. check all contacts, engine grounds too, for corrosion and clean if necessary.
Testimonial: "Yes did every thing you said and found that the problem was the main relay fuse. must of saved me about $200.00 bucks."
Check main relay and it's fuse.
Get the battery charged outside the car.
You can get it checked and charged free at AutoZone and other shops.
?Several cars lately have had the same symptoms, and the problem turned out to be a bad ignition switch.
Since the ignition switch goes directly to the battery, it's worth a check.
Hope this helps.
SOURCE: NO POWER !!! 1990 supra
I had an issue with the smaller wire off the positive battery terminal breaking inside the casing. Damn hard to find! I would suggest giving the wires around the battery a wiggle, and a feel. Could be a loose connection.
SOURCE: I had my car towed
The ignition relay is faulty.
Look into that.
Please accept this answer to remove the multiple occurances of this same question from the work queue.
Thanks!!
SOURCE: worked fine drove it - now won't start only headlights battery ok
check the battery voltage and make sure your connections are clean and tight.
SOURCE: this problem just started you
sounds like the starter inhibitor switch(stops you from starting the car unless its fully in park)
SOURCE: my 2003 toyota corrolla wont
More than likely it is your starter solenoid. The starter will have to be removed. Here is a link to tell how to get the starter out. http://www.ehow.com/how_6496417_replace-starter-2003-toyota-corolla.html
