Sentry Safehttps://www.sentrysafe.com
SentrySafe offers a broad range of secure storage solutions to keep your valuables protected from unexpected perils, theft and more. View safes.
? 8:22
https://www.youtube.com/watch?v=u3p5KUNfDG0
May 15, 2015 - Uploaded by Mr. Locksmith
New Sentry Electronic Fire Safe Opened in Seconds with No Sign of ... Marc Tobias and Terry Whin-Yates open a locked Sentry Fire Safe in ...
? 3:41
https://www.youtube.com/watch?v=Zy5kJ5Uqa2o
Jun 7, 2012 - Uploaded by PAWS611
You saved me from destroying sentry fire safe with a mini-sledge and .... haha haha doubted you at first but I got it open just kept wiggling it ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
Locksmiths agree on how to install sentry safe batteries slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
To install sentry fireproof safe battery slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Sentry Home Safes battery location slide open the battery cover located just below the keypad. Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated. reconnect the connector and put back the battery holder. Slide the cover back in place.
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, next replace the electronic lock case and turn to the left to reassemble.
I have the same problem. What is the solution?
I have the same problem and it's just not locking. I tried pulling the handle as hard as i can but still not able to get it to the locking position
