You cannot restore when your mobile is switched off. Switch ur mobile C2-03 go to settings, then scroll down to the last option restore factory settings.....they will ask you whether you have to restore simply settings or all data? It is on ur wish...select option, then enter the security code 12345 then click restore...ok. You will get your mobile restored!!
You want to restore the BIOS setting? You don't need any CD's for that. Simply go into the BIOS setup by hitting F2 when you first start the machine; that will take you into the settings screen. If you're trying to reset the OS to factory default, you will need to have the CD's and the key code.
Factory settings only on BIOS. so you can restore it through bios, usually loads as default settings (depends on motherboard and models)..To completely reset/restore BIOS, can just simply remove battery for about 2-5mins and plug it again on motherboard.
You can simply done it by dialing *#7870# on your standby menu. After confriming just provide your current master/security code. Then the phone will restrat, wait until it restart byself. Before making restoring just check your battry is enough or not and never remove your phone battry while restoring
For (Operating Systems=windows98,xp,vista)
unless you have a custom program to do this you can only restore back using (system restore) however that will not restore it to factory settings..
the best way is simply re-installing the Operating system after Formatting your entire Harddisk space (all partitions)
If you don't know how to do it.. then simple follow the instructions after booting the windows CD
PS: to boot windowsxp cd you have to set BIOS settings (F2 or F10 or Del Button at start of computer)
to boot CD before HDD..
There is no simple restore factory settings in Laptops
