I have an installed version of PC America Restaurant Pro Express. I had a working configuration at one point. Kitchen printer stopped working so I stopped using it for a few months until I had time to fix it. Now RPE won't start up at all. I get an error that an exception was encountered and that cresql cannot be opened and the login failed. Then 2 more dialogs come up saying that it cannot find the necessary data tables. I cannot even get to the credentials screen for RPE. Nothing opens. Any ideas?
Check to see if the SQL service is running. Go to Control Panel, Admin Tools, Services. These three should be started. SQL Server (PCAMERICA), SQL Server Browser, and SQL Server VSS Writer. It sounds like you are having a connect problem to your database. Did you do any RPE upgrades or conversions? Since you let system set for several months, I assume your free tech support has expired. If not, contact them today. Don't wait. Otherwise, you need tech help. I'm available at a much more reasonable rate than PCAmerica.
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
SOURCE: Restaurant Pro Express - my client workstation
the default user is 'sa', the default password is 'pcAmer1ca' for the database.
SOURCE: Syncing client with server - Restaurant Pro Express
Your getting a connection successful because your looking at the localhost. The server would be the network name of your server. And the password is case sensitive and is pcAmer1ca. (Note the number 1, not an i)
