Can you use the kodak trays in the Vivitar 3000 AF Slide Projector
SOURCE: Carousel projector slide not working right. Can
I had a similar problem and was able to get the full view by giving the change button a quick touch for a partial activation. It seems as though the cycle does not complete before the motor is turned off at what should be the end of the cycle. I took it apart to find the problem but did not discover the correction. So the little "flick" on the change button finished moving the slide into position and the "blocker panel"(inside the projector)) out of the way so the whole slide could be seen.
SOURCE: I need a new lamp
Check with: www.bulbman.com They have an amazing assortment of lamps for all vintages & brands of projectors!!
