Check for spark when it cuts off also check the oil level some have a low oil shut off also dry and run it with the gas cap loose to see if the vent is plugged
If it did not start and die when you used starting fluid then check to see if the plugs are getting spark. Check to see if injectors are pulsing. Could be bad crank sensor. Need scanner to check further
can you hear the fuel pump kick on when you turn the key on but without crancking the engine? Generally the fuel pump will prime for about two to three seconds when you first turn the key on. if you don't hear it that's probably the culprit. If you do hear it it may be a bad pump. also should check to see if you have spark. You can do this by removing a plug wire and using another spark plug. Ground the plug to somthing metal and have someone crank the engine (making sure you are not touching the plug or metal) You should see a spark while cranking. Good luck
