Question about Generac Electrical Supplies
How do i reset overcrank alarm on my generac 0058750 generator
Posted by billieswishe on
  • Anonymous Mar 13, 2014
    I have kohler model: 60HZ I have a problem when I start the generator overcrank start alarm So what can I do to reset it
delaina5
    New Friend:
You turn the unit to the off position, hit enter twice on control board, and put back in manual, this should reset this fault
Posted on Sep 08, 2011
I have a red light and message Stopped-Alarm Overcrank. what could be done
it didnt start after cranking 3 times. its probably time for service and a valve lash adjustment, clean battery terminals etc etc
Apr 19, 2018 | Generac Electrical Supplies
Overcrank alarm in Kohler Marlene engine
Overcrank alarm is coming because the unit failed to start
Mar 16, 2014 | Electrical Supplies
Generac 20,000kW Standby generator doesn't start shows message STOP ALARM OVERCRANKED
Overcrank means that it tried to start and couldn't. It will go through 5 crank cycles and then stop with this alarm. Switch to off, hit enter to clear fault and then try to start in manual. Check to make sure you have fuel and pressure is 11 to 14 in WC.
Jun 21, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
My generac 15kw generator went off on overcrank now the relay just clicks then stops then clicks agin, i have 13 volts at the battery
It could be either your start capacitor or the contactor-relay. Or you could try cleaning the contacts of the relay with an emery board to see if there is a change.
Sep 07, 2011 | Kohler 12 kW Emergency Power System -...
I have an older 30KW Generac SG 030 1800rpm running on Nat Gas which I bought used. It has set up for several years. I installed a new PN0830890SRV master control board I bought from the local Generac...
need to calibrate the main control board. 83089. also is it overspeed or overcrank? if the board does not see the right rpm or is blow a certain threshold it will think it has not started yet and shut down on overcrank.
Mar 13, 2017 | Generac 13,000 Watt / 13,000 Watt Home...
Overcrank error message
The 'overcrank' error simply means it tried to start but never actually started. It cranked for an extended period. Check the fuel and starting issues you would normally check to start the engine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Mar 31, 2009 | Kohler 12 kW Emergency Power System -...
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Mar 29, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
10,071 people viewed this question
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
