Question about Generac Inverter Ix2000 Gas Portable Generator......new
I have a generac ix2000 and has an overload light on with no AC power out. what do i need to check?
The only thing i've done is check the voltage coming out the plugs but i get no readings
Posted by cam trevino on
cwradio73
  • 1,162 Answers
When you have a generator with a inverter in it you have to be careful of overloads an static electricity. More than likely one or more otf the MOSFETs has blown. An inverter is really a switching supply. Not very hard to replace parts but if you have spme skill with electronics take it apart an give it a go. If transistors have not blown you may find a blown fuse inside on circuit board. You will never find a schematic for any of these units. They are protected because the dealers pay to much for selling rights you cant hardly get them. But i would take it apart an see what you have. Or find a good electronics guy an ask him to check it
Posted on Jan 28, 2015
I have a 15kw generac genset and it has an "overload remove load" fault which can be cleared from the evolution controller. genset started but shutdown after 5 seconds.
The overload fault is indicating that your connected load is overloading the generator capacity and it's tripping off. Check your connected load (what ever is hooked up that you're trying to power). You need to use an amp meter to verify the amp draw, and also the rated voltage output. If it's low voltage, could be low engine RPM or voltage regulator. high current indicates a problem with load your trying to power, ie-- Motor or other load.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jan 24, 2018 | Generac Electrical Supplies
I have ix800 overload light is on wont produce power.what could be the problem?
Two things come to mind, (1) the unit is carrying too much of a load. Unplug everything and try again, and (2) the inverter assemble is defective and needs to be replaced (most likely cause if nothing is plugged in). (Still under warranty?)
Jul 08, 2016 | Generac Power Systems Generac iX800 Watt...
How do I fix this problem
You are drawing to much power and if your not drawing any power and that light is still on then the breakers in the gen are toast
Oct 12, 2014 | Generac iX2000 iX 2000 5793 Portable Power...
Generac ix 2000 how do I adjust fuel mixture
im not suure what you mean about "Bog" but this gen is only good to 1600 watts cont. (2000 peak) and it has a auto throttle so it will idle down all by itself when not loaded past say 40% of total load , but if you think your having fuel starve problems try all the simple things 1st Fuel filer (inside tank) clean carb and stuff like that , I do fix allot of small engines with a good strong dose of stp fuel treatment and i never need to take em apart
May 30, 2014 | Generac Ix2000 Portable Generator Inverter...
Generac troubleshooting
check that the over load switch is not seized of course then replace
Dec 28, 2017 | Electrical Supplies
Ix 2000 surging
YOU NEED TO AJUST THE FUEL MIX ON THE CARBURTOR
Nov 06, 2012 | Generac 5793R iX2000 iX Series 2000 Watt...
Generac generator on auto runs weekly. light green previuosly green. now red. what causes this??
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Kelly
Aug 30, 2010 | Kitchen Ranges
I get no 110 or 220 volt power
generac was purchased by Briggs Stratton some years ago, however some information is available at the following web address, just enter your model number:
http://www.generac-portables.com/service_support/owner_manuals/owner_manuals.cfm
The small board that you describe is the bridge rectifier that converts ac from the windings to dc for the armature. You can test the brush/board by removing the part from the generator and applying 12 to 16 volts ac to the input tabs/wires then test/read dc (dc voltage will be lower than input ) voltage at the brushes. Use meter to make sure that you are getting dc. I use a small power supply less than one amp that I purchased at the thrift store for a couple of dollars. If test fails replace part. If it tests ok re-install brushes and re-connect the ac power supply to brush/board which in turn will energize the armature. At this point test the armatrue for magnetic power. I use a thin welding rod or wire against armature. If you feel a magnet start the engine. If the windings are good you should get some voltage at the plugs and the two wires that feed the brushes (will not be full voltage). If voltage is present, kill engine and disconnect ac power supply and connect the original wires to brushes/board and start engine. If you now have voltage at plugs you spiked the system indirectly by energising the armature. If still no voltage you may have an open circuit that feeds the brushes or diode pack is failing with the incresased voltage. Good luck with your repair and email if you have questions.
Apr 12, 2009 | Electrical Supplies
Generac Inverter Ix2000 Gas Portable Generator......new Logo
5,742 people viewed this question
Top Generac Electrical Supplies Experts
Bill Johnson
Fahr Quad
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
