Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SOURCE: memory card error in powershot SD1100
Try a retailer near you to see if they will allow you to test your camera with a SD card from a display camera.
Good luck, I hope this helps!
Gom
SOURCE: memory card is write protected
Take your memory card out of the camera and switch the position of the little "lock" tab. That should fix it and you can start saving images.
SOURCE: unwrite protect olympus Fe 280
go to set up and reformat. This will fix the problem
John Harlow
SOURCE: My Olympus T-100 camera is showing writing protect
can mean that the memory card is locked. take out the memory card and check for a lock slide at the sides of the card that you can adjust to a lock and unlock position, then test the card again.
SOURCE: my camera memory card has been deleted but my photoes recover by any software plz tell us
As a matter of fact, no matter your photos in Canon camera got deleted, formatted by accident or became inaccessible due to camera memory card errors. Chances of recovery is possible as long as you take the right action.
Take a try of this tool to recover photos from Canon, Not only general photo formats, but Canon RAW photo formats (.cr2 or .crw) can be retrieved easily.
Note: before the photos are recovered, Never should you attempt to take more photos or save more data to the memory card in case chances of photo recovery might be reduced. Hope it helps. Regards.
