I'm getting or being harrassed for other people using my number. I want my phone not to except voice mail. How do I do that unset the voice mail option.
SOURCE: Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
SOURCE: Message Greeting
The KX-T7456 is a proprietary system phone. You have a Panasonic phone system and a voice mail, both separate items with their own part number. Your phone can work on several different systems and use different voice mail so your first step is to determine the part numbers from the system and voice mail. Then you will need a "programming" manual or possibly "administrator's manual" NOT a "user guide" for at least your voice mail and maybe for the system as well.
SOURCE: voice mail greeting
Sign in to mailbox 999 and 998 and poke around. You should find some greetings in there. Else, if you have the installer software you can go in from that and make the changes.
SOURCE: How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
SOURCE: Voice mail greeting
When you log into the mail box, option 8 will be for personal options. Then option 2, will allow you to record your personal greeting. If this is a Startalk vociemail.
