How do i find recharge componets on motherboard a215-s4807? battery won't charge, and will not accept ac plugged in the wall. also drains battery if connected or plugged up to charge.
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
SOURCE: I have a toshiba laptop
certain laptops rely on a battery being present.
Or a battery that holds charge.
i,d suggest refering to the user manual, or go on-line to the manufacturers website.
the laptop may be in hibernation/sleep mode. or require a hard reset.
visit toshibas support site for further details and faqs ( frequently asked questions )
Mike @ compurepair.
have you tried before to reassemble your laptop? if not...dont do that...because it will damage your laptop..if YES....open the laptop...remove the motherboard and replaced the power jack of the motherbaord...be sure that you find same model of the jack....if you find desolder the old jack and solder the new jack and return to assmble you laptop and put the charger and power on...good luck am 100% it will work..because this is my job..if still not work..dont hesitate to contact me..
SOURCE: how to repair satellite a215-S4807 black display?
your user profile may be corrupt. after turning on your laptop press F8. choose "last known good configuration" and see if that resolves the problem. if not, next choose "safemode". from safemode click "yes" to continue and restart the computer from the start menu. if this doesn't work, go back into safemode. click "no", and restore the computer to a early date when it was working.
SOURCE: Netbook charging indicator light won't light
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead.
2. the battery bay is loose
3. the battery itself is loose
Hope this helps...
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi:
Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link:
http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
i have replaced the motherboard, and now i don't get any video and does not post. but it switches on does not turn off by the power switch.
