Liftmaster garage door opener will open and will not close. Had a lightning strike replaced the sensors on both units. One now works the other will only open and not close. Holding the button does not help close it. Rechecked sensors made sure they are clear and the green lights are on. Walking past the sensors after hitting the button does make the unit lights flash. any ideas?
SOURCE: Liftmaster 1280 LMC Motion Detector Garage Opener Push Button Pad Not Working
Have you tried to reprogram the chanel again?
Changed the battery?
SOURCE: Garage door only opens with wall unit
a component in the wall unit is failing , that makes the conection happen when the remote signal is recieved , ( it is recieving the remote signal but not sending it out to the control circuit for the motor )
SOURCE: Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
SOURCE: liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
SOURCE: Liftmaster garage door opener not working-flashing green lite
GOTO http://www.liftmaster.com/consumerweb/service/manuals
DOWNLOAD THE MANUAL FOR YOUR UNIT.
CHECK OUT THE DIAGNOSTIC SECTION.
HOPE THIS HELPS
