Hello everyone, im having an issue with my brake lights? checked fuses, all ok, any suggestions why my lights stil not working? and another question i was out so my brother used my jeep for a year,then i came back saw my lights switch for interior and exterior, turn signal ******! so i cant control iternal ilumination now.. any suggestions? hope you could help me out with both of my problems!
To solve your problem the best way is to visit on the link given and your problem will solved http://toolsnyou.com
SOURCE: 2003 Jeep Liberty heater fan problem
It is the blower motor resistor. Look under the passanger side dash and locate the fan housing (looks round and black in color. Then locate the resistor it will be in that housing usually withtwo ten millimeter nuts or two simple screws holding it in. unplug the harness to the resistor and remove the resistor. Part store price is approx. 50.00. Note: on aftermarket (not Jeep) resistor sometimes you have to modify the housing a little to get it in. Hope this helps.
SOURCE: 2005 jeep liberty brake lights will not work. I
brake pedal switch, get a wire, unplug plug, bridge circuit and check lights.
plug and switch is high up on the brake pedal not normally easy to get to.
SOURCE: check fuse replace brake light switch, and still
first check the fuse for the stop light circuit, if it's good, check your bulbs, it's possible they are all burned out! take one of them out, swap in a new one, and see if it lights. If not, get a wiring diagram and start checking for your powers and grounds. Take a look at the stop light switch on the brake pedal. If it's no good, there is a good chance that your cruise control may not work properly either. Good luck.
SOURCE: 2003 Murano interior lights all stopped working at same time.
if the problem is that the interior light does not work, and have already checked the fucibles and appear well or not, housed the correct fuse. Just disconnect the battery cable and connect buelbelo .. and you will be surprised to see that your lights funcionana. I do not believe it but I worked it costs nothing to test.
also middle light is not working, all three brake lights are off?
