Gracias Jorge Sanabria por darme la oportunidad de responder tu pregunta.
Chequiando el internet me doy cuenta de que el Samsung DVD-R130 DVD Recorder no es un producto que lo recomiendan por clientes . Esta es la informacion que encontre.http://reviews.cnet.com/dvd-recorders/samsung-dvd-r130/1707-9141_7-31738526.html?tag=mncol;lst#manDesc3 de 10 compradores no recomiendan este producto. Mi opinion personal es de que si lo puedes regresar eso fuera lo ideal pero si no se puede asmelo saver y buscamos una solucion para este problema. Si esto soluciona tu problema x favor as grado mi respuesta.gracias ============================
Thank you Jorge Sanabia because you give me the oportunity to answer your question.
Checking the internet I notice that Samsung DVD-R130 DVD Recorder is a product that is not recomended by the customers.
This is the information I found.
3/10 customers don't recomend this product.
In my personal opinon is that if you can return it, that will be the ideal but if you can't please let me know to find a solution to this problem.
If this solution solve the problem pleas grade my answer.
Tahnk you
Without knowing more of your specific situation, it sounds like the disc is physically stuck and is blocking the motor mechanisms from ejecting. There should be 1-2 screws on each side & one at the rear of the player to remove the outer casing. When you open it, any obstructions should be obvious. The screws should be easy to figure out with an arrow pointing to them stamped into the medal, kindof looks like: =>
