Vehicle shifts Hard into reverse or drive, when in drive it will not change gears. Doesn't go faster than 30mph
Did you ever get that problem diagnosed? My 2008 Jeep GC recently and frequently gets stuck and does not accelerate past 1st gear. We have to pull over put it into park then shift into D-rive again. Then the transmission accelerates prperly. The only way we knew this was the big trucks on my job site have to do the same thing. A temporary resolve. Hoping it's not the transmission slipping and needing repair.
SOURCE: noisy shifting
I'm wondering if what you are hearing is the driveshaft universal joints. If they are worn they will 'clunk' every time you put the vehicle in gear. Block all wheels to check, put vehicle in neutral, NOT running, crawl under and move the driveshaft back and forth while watching the front then rear u-joint. It should be obvious if there is 'slop' or 'play' in them, which would indicate they need to be replaced.
Testimonial: "thanks for the response. i will follow your advice "
SOURCE: 2005 Jeep Grand Cherokee Shifting Problems
Check the Trans fluid level with it running and at operating temperature. Jeep NAG1 transmissions are known to have the input electric seal leak trans fluid. Not an exspensive fix add Mopar ATF4 and then relace the guild seal.
SOURCE: shifting lever doesnt lock
Likely the shift detent mechanism is broken. It's inside the unit and can be reached by removing the trans pan. It should be just inside where the shift lever goes through the case.
SOURCE: Eratic shifting of gears at speeds of 55 to 75
I would check the transmission fluid level and color, should be a nice clear red color. You may need to have the filter replaced. Possibly some internal transmission problem also.
SOURCE: I have a 2000 Jeep
They way you replaced fluid is bad, you should of done a bg service, by dropping the pan theres still oldoil ,the converter is full and the lines and the cooler and inside trany, then when new fluid is added the cleaners in it loosen all the dirt and seend it through the trany, the bg flushes 100% of the old fluid so no mixing of old contiminated and new oil is taking place.
