Canon EOS 40D Digital Camera Logo
Posted on Dec 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon 40D images are out of seqence on computer
When i download images to my pc, odd images are out of sequence.
Also they are not rotated even though i have changed the settings.
Anonymous
Level 2:
  • Expert 154 Answers
  • Posted on Dec 16, 2008
Anonymous
Expert
Level 2:
Answers
154
Questions
0
Helped
89998
Points
474
When all of the images are downloaded to a folder, click view, arrange icons by, name. All the images should now be in order. To rotate, richt click the image, select preview and use the rotate buttons on the bottem of the pageCanon 40D images are out of seqence on computer - 4f0e0d4.jpeg You can also use many photo manipulation programs such as photoshop, serif photo plus etc to manipulate the images
Can't transfer images from my canon 40d to
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Split images
use good antivirus with updates and then transfer ur images and cd write it
half middle pic is due to speed of ur pc and viruses
1helpful
Photos are super over exposed when using 430 Speedlite w/Canon 40D, even though the settings are per the manual
if overexposed, what yuou can try and do is make the shutter speed faster (so less light reaches the sensor) or reduce to the ISO setting to 200 or lower as needed. Both these will help with overexposed images. I wouldn't recommend consulting the manual because there are so many variables... The manual doesn't know exactly how much light there will be in very shot you take, and that is the crux of photography, working out what settings work best with the light available for each shot.
Hope that helps!
2helpful
3answers
40D not communicating with EOS utility
open device manager, connect camera, it will be seen briefly with yellow triangle and exclamation mark. open it up and uninstall.
Disconnect camera and close windows down. Restart windows, connect camera and switch on, windows will then find it and install driver. Took me hours to figure this one out
Switched to MAC - have EOS40D and SX100 - will not download SX100
Yes, you need to install the SX100 driver software as well. I wouldn't overwrite older versions of the Canon software, though, so do a selective install if you can.
2answers
Canon EOS 40D won't export my pictures onto my computer
Have you tried the "Adobe Camera Raw"- plug in for Adobe Photoshop, it should handle CR2-files whithout previous conversion. It is sometimes best to load the images from within a program like iView or just drag the images into a desktop folder. I think iPhoto is somehow the default program (possible to override, though).
3answers
Downloading images
I got a same problem so I contacted canon service center. But the technician said there is some problem on my computer or window system, And he recommand me to purchase a multi merory card reader to solve the same.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
