The car will be driving just fine then a light comes on it looks like a little wheel with an exclamation point in the middle..then the tachometer goes nuts and the car stops taking gas and then eventually dies. After a few seconds it will start and go just fine. It does not happen all the time..is it the oxygen sensors??
Visit the on-line store, known as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
1994 BMW 3 Series
SOURCE: BMW X5 2000 problem
hi. did you try to start with the orther key, all bimmer the keys has immobilizer ( key security system build in), some time it lost memory by it self.
good luck
SOURCE: BMW 328 i 1997: Start up problems / Stuttering / Engine Light
change the pcv valve its under the intake manifold
SOURCE: 2001 BMW 325i problem: Car runs very rough, but no warning lights
Sounds like a fuel problem , have you changed the fuel filter in a while ? could be the knock sensor or the knock sensor module needs to be replaced.
SOURCE: 1997 bmw 328i not starting
Come on give us more information. Think if you were trying to fix your own problem and you had to explain the problem to someone else with exactly no knowledge of what's going on.
1st off....a key with bad electronics and reader will open the door and that's it.
So that being said does the key turn the engine? If so the key, the program and ecu are ok. Say the engine cranks but doesn't start. Fuel pump. unscrew the access plug on the fuel rail and see if any fuel squirts out. NO......don't ever do this when it's hot..........not that yours is because it doesn't run but I had to say that. The millisecond you turn your key over to get it to try to start...the fuel pump comes on and pressurizes the entire fuel system.
Got fuel pressure, the engine turns but still no start= ignition spark plug engine computer problems.
