Engine makes a tcking sound when I start it but oes away after a few minutes
SOURCE: 2005 Ford Escape Hissing sound
The power brake booster has a bad valve. I can't suggest where to find a new valve for it, but you can buy a rebuilt replacement. They are usually not hard to put on.
SOURCE: Engine will not turn over, makes a clicking or rapid clicking sound
you are correct it is the starter the clicking you hear is the bedix wheel which spins the flywhell to crank the engine. replace the starter and this will solve the problem
SOURCE: 05 ford escape wont start. jump started it and it
okay try this....talk to your parts store and get a battery load tester, and find out if the battery is indeed dead. My guess is it sounds like the Altenator is dying. they are around 50-100 and can be install by a pro in minutes.
SOURCE: Ford Escape Hesitant to start, gauges going crazy?
there is a short in the system a good shop ill have to trace it.
SOURCE: My ford escape 2005 start to vibrate shortly after
You could have a worn out U joints, if your only getting the vibration during the acceleration period. Check the condition of the U joint to the drive shaft and tires. Good luck and hope this helps.
