Yamaha Ef4600/5200/6600/yg5200/yg6600 Generator/inverter Repair Service Manual Logo
JDjr Posted on Jul 24, 2012
Valve adjustment for yg5200 - Yamaha Ef4600/5200/6600/yg5200/yg6600 Generator/inverter Repair Service Manual
How do I adjust the valve clearance on my 1989 Harley Davidson sportster ?
The Harley forums are full of great advice.
sportster valve adjustment
Harley Davidson Forums https://www.hdforums.com > ... > Classic > Ironhead
Sep 10, 2012 - Option 2: Adjust on the looser end of the range: Set the adjusting screw to finger tight so that you cannot turn the push rod between forefinger ...
Valve Adjustments - Harley Davidson Forums
Aug 21, 2007
99 Sportster 883, are valves adjustable?
May 11, 2010
Valve Adjustment - Harley Davidson Forums
Apr 21, 2008
valve adjustment on TC96? - Harley Davidson Forums
Dec 17, 2007
More results from www.hdforums.com
1helpful
Valve clearances for a 2.5 turbo diesel ford courier Pe 2000.
intake 0.20mm exaust 0.38mm adjusted with engine cold.
with 1 and 6 fully open - adjust valves 4 [inlet] and 7 [exhaust]
valves 2 and 3 fully open - adjust valves 5 ex and 8 in
valves 4 and 7 fully open - adjust valves 1 ex and 6 in
valves 5 and 8 fully open - adjust valves 2 in and 3 ex
Rotate the engine clockwise only between adjustments
08 Civic EX, valves became noisy at60K, valves quiet after warmup. They will probably still be noisy after I adjust them. Would the cause be excessive wear on the valves stem ends and rockers?
If there were no wear, the valves wouldn't need adjusting. The reason for periodically adjusting the valves is to compensate for the wear that the valve train undergoes over the life of the engine. Be optimistic! Have confidence that adjusting the valves will reduce the noisy valves.
Uberhaus toilet fill valve will not open to let tank fill
Maybe something wrong with the mechanism inside the toilet fill valve. Try to adjust the fill valve first. I found this one about adjusting fill valve, I hope it can help you.
ADJUST MOEN TOILET FILL VALVE 5300 Home
If the problem remain after adjusting the fill valve then I will suggest you to buy a new toilet fill valve and replace with the old one.
Thanks.
Oct 06, 2013 • Home
1helpful
2answers
Valve lash procedure
i need to know how to adjust the valves on 02 pont sunfire
Need to find out how to adjust vavles
If your engine is an overhead valve Briggs. You need to:
Remove valve cover
Locate rocker arms. Upper is exhaust, Lower is intake.
Loosen the lock screw in the center of the adjusting nut.
With engine at TDC and both valves closed adjust both valves by turning the adjusting nut to obtain proper clearance. Once set, tighten the center lock screw.
Valve adjustment specifications vary from model to model. Would need more engine information to get you that or it can be found online.
Reinstall valve cover, make sure gasket did not get damaged.
Adjust valves on a "cold" engine.
5helpful
2answers
Overhead valves making noise like they need ajusting
Valve Lash ADJUSTMENT 1.6L Engines NOTE: Measure valve clearance with the engine cold.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Remove the valve cover.
  3. Set the engine to Top Dead Center (TDC) of the compression stroke for the cylinder to be adjusted.
  4. Check the valve clearance. The valve clearance specifications are as follows:
    • Intake valves: 0.005-0.007 inches (0.13-0.17mm)
    • Exhaust valves: 0.005-0.007 inches (0.13-0.17mm)
  5. After adjustment, tighten the locknuts to 11-14 ft. lbs. (15-19 Nm).
  6. Repeat for each valve to be adjusted.
1.8L, 2.0L and 2.5L Engines The 1.8L, 2.0L and 2.5L engines utilize automatic hydraulic lash adjusters to maintain proper valve lash at all times. Periodic valve lash inspection and adjustment is not necessary or possible. prev.gif next.gif
9helpful
3answers
I have a 17hp briggs and stratton vertical intek engine that needs the valves adjusted again. What are the adjustments for the valves?
adjustment with 4000 feeler gauge
adjust top valve when the bottom valve is fully compressed and than with the top valve fully compressed adjust the bottom valve the same way.
very easy But remember to losen the center tork screw before adjusting the rocker arm nut
2answers
New rebuild chatters
adjust your valves your oil pickup tube needs to be adjusted you need feeler guages to adjust the valves down properly
make sure lifters and oil pick up tubes are not clogged
feeler guage is---> thin pieces of metal cut to different sizes to hold under valve adjusters till the play and chatter gone
check by book what the feeler size needed for adjustment
Top Yamaha Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
MrFixitSTTL
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
