Computers & Internet Logo
Posted on Dec 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gateway Solo 9550 will not power on at all.
I read on the internet that this means its power board is dead or the hard drive failed.
If its the power board, where do I get it fixed. Are you in located in San Diego, CA?
  • Anonymous Jan 15, 2009
    I had the same problem. I used a different power cord (not the adapter, the three-prong cord that goes from the wall outlet to the adapter) and it booted up just fine. The battery on mine is dead as well, but it may be possible to repair it (more info here as well). Let me know if you're able to repair yours or if you can get it to power on as well.
Glm laptop & computer Repair
Level 2:
  • Expert 201 Answers
  • Posted on Jul 21, 2009
Expert
Level 2:
Answers
201
Questions
Helped
69005
Points
456
First you would try the least expensive
make sure your ac adpater works
the plug could be bad on the end
next is the pin inside the dc jack where you plug it in, if the pin moves just a little , you may need a new dc jack sold on ebay cheap
make sure the battery is out when testing
Gateway Solo 9550 bios unlock password master
There isn't one, either take the laptop apart and remove the CMOS battery for 10 seconds or download and burn hiren 15 to a CD and use one of the CMOS password wipers.
I need the size or model number for a replacement charger for the gateway solo 9550.
Compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery.
I have a solo 9550 with XP and everything crashed, the only thing it would do is keep restarting and never would load up windows. I tried all of the F keys to try to find the gateway recovery center but it...
It'll not help you, due to symptoms of ailing hard drive.
Go to your BIOS and see if there any Hard Drive status check (like S.M.A.R.T.)
If not, get somewhere (DOS based) HDD test that will run from CD/USB without Windows running.
Quick question regarding the Gateway Solo 9550 laptop. I cannot connect to any wifi network. The laptop recognizes networks by name, but it does not connect. Any ideas?
Try clearing your winsock///Click start...Go to run..type cmd....Then type netsh winsock reset. Computer will say need to reboot but not nessasary
I have a gateway solo 2500 with trying to use a samsung 40gb harddrive cdrom reads up but wont formate the harddrive why help please
The Gateway Solo 2500 model computer accepts hard disk drives up to 6gb. The system is not able to correctly read and use a 40gb hard disk drive.
1helpful
My Gateway 9550 will not power on.
The power adapter, dose it match the voltage and the polarity shown on the bottom label of the laptop?
The voltage will be shown in V, for example 19.5V
and the polarity will look like this:
Make sure the charger is the same polarity as the laptop label says on the bottom, if its incorrect it may ruin your laptop.
1helpful
I have a Gateway Solo 9550 wont boot
it seems issue is very sensitive and without taking look at it problem can not be sorted it can have multiple problems............please contact manufacturer
AUTO SHUT OFF
it is most likely overheatiing... you need to disassemble it to the point that you can clean out the dirt and dust in the fan and cpu cooling area.
Solo 9550 gateway won't boot up windows
in safe mode.
Go Start>Run type 'msconfig'. select the box that sais - hide mocrosoft
Untick any boxes that arent microsoft products.
On the startup tab, unselect any boxes that are unknown manufacturers or manufacturers like HP/ Yahoo/ etc. Not Radeon or NVid though as they are your graphics
Reboot
2answers
Battery
get a battery with a close model number
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
