My computer is not detecting the CD-RW. When i checked it shows that the driver is not installed.
May be there are some cable fault. Just check that the cable CD-RW to Motherboard and the power cable from SMPS attached in CD-RW is ok. Then try. If it works then fine. If not, then just format C drive(Or where u have installed the OS). Coz I've already gone through a problem like this. In that case the cables ware ok. Then I just format the C drive and install a fresh copy of XP. And works fine till now.Let me know the result.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Same **** for me mate :S
