Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Safe Mode Enable Boot Logging Start Windows Normally Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator it will prompt you to enter the new password enter the new password and the password is changed
Please select an option:
Safe Mode with Networking
Safe Mode with Command Prompt
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
hope this helps
SOURCE: unable to login to laptop due to forgotten login password
First thing you can try is:
1: When booting up the laptop Press F8 until you see a screen show that has an option to boot in "Safe Mode"
2: Once it has finished booting up you can Select Administrator and hopefully there is no password set.
3: If there is no password set then login as Administrator and goto "Control Panel", Select User Accounts and change your daughter's password to something she wont forget ;p
if that fails then you can try this
http://www.lostpassword.com/
Offers a program that resets your passwords.
Hope this helped.
SOURCE: gateway login screen
Restart the laptop, hit F8 repeatadly to start in safe mode. This will bypass XP's login screen. You can then manipulate the password in the control panel. Also, you can change it by going to commandprompt, type: net user * (your username) then whatever password you want.
forgot login password
