New graphics card is NVIDIA Geforce 8400 GS PCI-E 512MB DDR3 and I am running Vista Basic
SOURCE: Need Drivers
Here's the URL for downloading Acer drivers. The audio drivers for XP are down near the bottom. Probably the first Realtek one will be what you want.
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%20T160.pdf?CFID=942322&CFTOKEN=64999962
SOURCE: I have an acer aspire
Are You sure the graphics card is not defect?
When I installed a graphics card instead of the onboard
circuit, the SIS Mirage was disabeled automatically.
I have installation CD for the graphics, of course.
Also, I thought that disabeling devices could be done
through the control panel, "hardware devices".
SOURCE: upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
SOURCE: Acer Aspire T180 is missing Video Controller Driver
Yes you would need the VGA drivers for the new OS. Please visit the site http://download.famouswhy.com/acer_aspire_t180_vga_driver/ and download the required drivers. Also follow the link below in future when you need drivers or any other SW.
SOURCE: Problem for Acer Aspire M1641- PC Desktop
It is not the monitor that is your problem. Your monitor is fine, it is a software problem with your CPU/Computer. You need to put your operating cd in the cd tray, boot computer in this order...cd rom first, then hard drive, etc. Your operating sysytem is corupt/missing some files, it won't boot up thru the hard drive, because it can't, it need to boot from the cd, where the files are that it needs.
Testimonial: "ok thanks for ur adviced..."
I instllaed the software that came with card and it does not see the bus video. Should I have done some setup prior to installing new card? I plan to pull the new card tonight and see if the bus video is recognized & the I am going to check CMOS & BIOS for settings. Any other ideas?
