Read your earlier post on a similar problem. I have a Sharp AR-C250 and have disconnected the sorter stapler because it jammed and the gears make a grinding noise. In the end, we don't use the sorter and I want to remove it. I am unable to test copier after disconnecting the cable because even after restarting, the code F1-00 still comes up to call for service. Do you know how I can clear the code to test the copier?
Thank you!
F1-15 is a problem with the finisher (sorter). The stapler is not rotating properly.Pressing Clear>interupt>0>interupt>1>4> start button may reset it for now. Good luck !
Sharp AR-450
H5
01
Papersensordefective in the fusing unit
02
Fusing unit temperature error
C1
00
MC unit malfunction
C2
00
TC unit malfunction
E7
00
Image Processing Unit error
01
Memory back-up battery dead
02
Laser unit problem
03
HDD defective
10
black level calibration error
11
white level calibration error
13
CCD calibration error
90
F1
00
Lost communication with the Sorter
01
Sorter registration problem
02
Paper transport motor overloaded in sorter
04
Bin position error in sorter
05
06
Shift sort motor overloaded
08
Stapler position error
08
Stapler overloaded
11
Sorter problems
14
Second shift tray jammed
15
Sorter drive problems
50
Sorter not installed properly
80
No powerin sorter
F2
00
ID pattern reading error
02
Toner add mechanism malfunction
31
32
39
Drum thermistor error
F3
12
Paper does not lift in the tray
22
F9
00
Printer board problems
01
02
03
Network card error
04
Firmware error
05
Not enough memory
10
90
H2
00
01
H3
00
Overheated fusing unit
01
H4
00
The fusing unit doesn't heat up
01
H5
01
02
L1
00
Scanner position error
L3
00
L4
01
Main motor drive overloaded
L6
10
Polygon mirror motor not up to speed
L8
01
Zero cross signal error
02
U2
00
EPROM error
11
EPROM error
U4
02
Duplex not working properly
03
Duplex problems
U5
00
Communication with the ADF is lost
01
Registration sensor problem in ADF
02
Exit sensor error in ADF
03
Timing sensor problems in ADF
11
Paper feed drive overloaded in ADF
U6
01
Paper lift problem in 1'st optional tray
02
Paper lift problem in 2'nd optional tray
08
Paper feed unit without power
10
PFU paper transport motor overloaded
22
50
Paper feed unit not installed properly
51
LCT not installed properly
U7
00
Main board malfunction
U9
00
Op panel problem
90
Op panel problem
EE
EU
Low toner density in the developer
EE
EL
High toner density in the developer
FA
01
PC
Key counter not installed
AR-S160(Japan only
) AR-160(Except
Japan) MODEL
AR-161(Except Japan) Exteriors Operation panel
section Side door unit Optical unit 2nd,3rd mirror
unit Middle frame unit Process unit DV cartridge unit Fusing unit Main drive unit Base plate unit 1 Base plate unit 2 Manual paper
feeding multi unit Delivery frame
unit TC case unit 250 sheets tray
unit Packing material
& Accessories MCU PWB ............................................. .....................
I have this one, but i can't send a file writ to me to [email protected]
Generally F codes have to do with the finisher(used to be called a sorter). with the machine off, diconnect the finisher cord from the copier and power back on. This should allow you to test the copier. I'm not sure on this model how exactly the finisher cord comes out. but it should be self explanitory when you see it.
In automatic detection of option connection, a non-support finisher or a sorter is detected. Unplug sorter/finisher and see if code clears, if yes you have a problem with the sorter (might not e the correct sorter for this machine) If the problem does not clear you may have a board problem with the copier.
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
f1-00
