my gas dryer heats up the first time then when it goes out it will not heat up again but i can see the glowing part of the dryer and then the glow just goes out.my gas dryer heats up the first time then when it goes out it will not heat up again but i can see the glowing part of the dryer and then the glow just goes out.
You can't post conmments that contain an email address.
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-... Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
If you are having problems with your gas dryer not heating
the most common problem is that the ignitor goes bad. Even though it glows
sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different
things that can go wrong causing the dryer not to heat.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
You need to replace the 2 solenoid coils on the burner valve . When one of them gets hot from electricity going thru it , it opens ( shorts internally ) . After the dryer cools down , they will work again until they warm up , then , no heat . Take your complete model number , when you get the parts .
hi .thanks for the question. the problem. is with the coils on the gas valve .replace the 2 coils. should solve your problem thanks the appliance doc.if you dont know how to do this get back to me
