Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA
I got a new spring on the rod that goes into the square plastic lift in the back of the icemaker compartment of the subject side by side refrigerator above (1996). When you move the front control to cubes, press on the dispenser pad,the actuator opens the delivery for cubes (I tape the door switch so the light goes out and the delivery system can work and I can see what is going on) but the worm drive does not turn to move the cubes forward to the outlet.
If I move it back to crushed ice setting, the actuator cause the opening not to allow cubes, the worm drive is engaged and moves the cubes forward to give me crushed ice.
What needs fixed to correct this problem? A switch needs to be replaced?
Where can I get directions for fixing the problem?
Model # is GE Profile TPX24PRYA WW (23.5 cu ft side by side refrigerator) Serial # is FR243275
To clarify the problem:
Original request was exactly how the new spring was anchored on the ice cube/crushed ice/water rod. I solved that, but the new spring did not solve the problem of not being able to get ice cubes out the door, but was able to get crushed ice and cold water.
Now I see that even though the rod is activated to open the ice cube tray door so that cubes can come out, that the driver that turns the worm conveyer for the cubes is not turning to move the cubes toward the opening. (On the crushed ice setting, the driver is turning to move the ice forward and chop the ice.)
What needs fixing to get cubes of ice once again when the control is moved to ice cubes?
Roger
----- Original Message ----- From: FixYa.com To: mruhler Sent: Saturday, December 06, 2008 9:05 AM Subject: Please clarify the problem you posted on FixYa.com
MNTECH has asked you to clarify your question to best assist with your Ice cubes will not dispense, but crushed ice will. GE Profile TPX24PRYA problem: Your post does not show which original problem you are referring to, but that is not overly important, because you do supply a fair amount of information on your problem. Could you please supply the full model and serial number of your refrigerator? Get it from the model / serial number tag inside the fresh foods section of the refrig. Click here to respond to the request.
Regards, The FixYa Team
--------------------------------------------------------------------------------------------------------------------------- If you do not wish to receive any further emails from FixYa, please unsubscribe here. Your privacy is important to us, Read our Privacy Policy to see how we protect it. This e-mail message was sent from a notification-only address that cannot accept incoming e-mail. Please do not reply to this message. --------------------------------------------------------------------------------------------------------------------------- < FixYa Email ID #40 Model # is GE Profile TPX24PRYA WW (23.5 cu ft side by side refrigerator)
Roger
From:FixYa.comTo:mruhlerSent: Saturday, December 06, 2008 9:05 AM
Dear mruhler,
Your post does not show which original problem you are referring to, but that is not overly important, because you do supply a fair amount of information on your problem. Could you please supply the full model and serial number of your refrigerator? Get it from the model / serial number tag inside the fresh foods section of the refrig.Your post does not show which original problem you are referring to, but that is not overly important, because you do supply a fair amount of information on your problem. Could you please supply the full model and serial number of your refrigerator? Get it from the model / serial number tag inside the fresh foods section of the refrig.
You can't post conmments that contain an email address.
Re: Ice cubes will not dispense, but crushed ice will. GE...
If the auger motor turns in either setting we know that the auger motor is OK, and if it does not turn in both crushed and cubes that leaves a problem with the WR55X129 time delay, which is the part that you switch to go from cubes to crushed to water.
Remove the ice bin, and in the back of the freezer you'll see a square opening with a white plastic piece inside. When you dispense cubed ice this piece lifts up, lifting the long metal rod that runs along the bottom of the ice bin. When that rod lifts it opens the ice flap at the front of bin, allowing cubes to be dispensed. If the flap is not open, the cubes will be ground against the cutters and you will get crushed ice.
Here's what you can do to make it so that you always get cubed ice. Take a wine cork and stand it on end. Using a good knife, I positioned the blade about 1/3 of the diameter from the edge and cut all the way through the length of the cork. Then remove the ice tray.
Now put your finger in the sqaure opening and lift up the white pastic piece. Slide the modified cork under the flap so that it is jammed into the raised position. (This is the position it should be in when you are asking for cubed ice.) Now slide the ice tray back in while using your left hand to push the plastic ice flap at the front of the tray to the left side (again, the position it should be in for delivering cubed ice). Peer under the tray while you're slowly sliding it back in so that you can see if the metal rod connected to that ice flap successfully slides into the square opening at the back. If it can't slide in above the cork-raised plastic piece, you may need to pull the cork back out and trim a little more off it.
This worked for me... I can't get crushed ice anymore, but I've only needed crushed ice once in the 16 months I've lived here so that's not an issue for me.
I had the same problem you do - the solenoid that lifts that white plastic piece is dead. But I also rent the place where I live, and it comes with the fridge. It's not likely the landlord will want to deal with this issue since I can still get ice, not considered a necessity, etc. So here's what I did to make it so that I always get cubed ice.
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58 http://www.apdepot.com/Buy/IPLFrame.asp?Brand=GE&ModelNo=GSH25KGMDWW&IMGFile=LD1IEWSN&IMGID=uZmA
No , the panel is probably ok .
1 ) remove the ice bin
2 ) in the back of the freezer , you'll see a square hole , with a white rectangle piece inside , which you should be able to lift upward , with your finger . If this piece doesn't lift , then it may be corroded with rust , or be bad . When you call for cubes , this piece lifts up and in the process , lifts the long rod , attached to the ice bin . When the rod lifts , it opens the bin flap , allowing cubes to be dispensed . If it does not lift , the cubes will be ground against the cutters , therefore , dispensing crushed ice .
3 ) to access this solenoid which lifts the cube actuator , remove the 3 or 4 screws on the sides of the PANEL , and with the panel removed , you will have access to the solenoid and actuator .
4 ) you can check the solenoid for continuity , voltage ( when arm pressed for cubes) , or possibly a loose wire .
This solution will work if you want to avoid replacing the solenoid and are willing to settle for alawys having cubed ice.
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
I had the same problem and just finished fixing it myself. 1st, slide out your ice bin about 3-4" and look underneath it. There will be a long brass rod running along the underside of the ice and goes into a little square hole below the ice maker. This rod runs the flap on the dispensor and keeps it closed for crushed ice and opens the flap for cubed ice. The is a plastic bar inside the little square hole that needs to be moved. Slide your finger onto the plastic bar inside the square hole and move it either up or down. Slide the ice bin back in and try cubed ice. If it doesn't work, move the plastic bar the other direction. This will fix your problem...........Good Luck! Dennis
Flapper door diagram is here, you can see how the spring, etc. work to hold the door closed.
http://www.partselect.com/Schematics/GE/00113173i04.gif
As for the crushed ice, (item 384) on the next diagram shows the little lever that lifts the side rod on the bin (item 329) to decide if cubes or crushed comes out. The solenoid (item 383) can get frozen up and not move. Take a look where screw (item 371) is, that little square window is where the device that lifts the rod is. Take a hair dryer and heat that area REAL good to melt the frozen solenoid mechanism. Test it every now and then by holding the door light switch off and pressing the cubed selection & lever. You should hear a very loud "clank" as the solenoid pull in to lift the rod on the bin.
Roger
To: mruhler
http://www.fixya.com/">
Dear mruhler,
Regards,
The FixYa Team
FixYa Email ID #40
Need to get part to install and check out solution offered. Thanks
