The dealership service dept. told me I needed new brake rotors+.
I checked autozone site, front rotors 1.020 thousandths rear .300. Yes, I agree, I wouldn't want them near my car. Of course, you're stuck because of trans warranty etc. An extra hour labor for a seized nut is ridiculous. These are so called 'professional' mechanics. This could take extra time, but 5 minutes, not 1 hour. If the fix goes extra easy, does the dealership drop the price? Of course not. At least not yours anyway! If u just replaced the brake pads, why do they say u need a brake job? I always have my rotors turned, but many people don't if they look good, and haven't gone metal to metal from former brake job. U need to go to micrometer reading at thinest wear point of rotor. If your brakes were pulsating, pulling, etc, the dealership could make a big deal about the rotors, but putting pads on rotors that are worn to approx. limit , but in good shape as far as wear and grooving, is not an issue here. I think u should try and find another dealer, or private garage for the future (good luck). When a tie rod is replaced, the # of turns tio remove it (from threaded sleeve) should be counted, and new one installed same # of turns to get to as close as possible to former alignment specs. It is a good idea to have alignment done again, as if it was a bit off before, it will be corrected to specs, so I do agree w/ the alignment of the car. Let me know how u make out.
