Turn unit on, E2 replaces temp setting almost immediatly. Owners manual does not discuss error codes in trouble shooting
SOURCE: no power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
SOURCE: my vent is too short
Try to extend the pipe using a pvc pipe or, some sort of pipe.use alluminum tape that you can get at your local hardwhare store to seal the crack in the pipe that you use to extend..
SOURCE: Amcor PCMB-12000E Portable Air Conditioner
you can get a part from any suppies store that sells a/c equipment ... some requier epa license .. but something like a fan u can buy that without a license ..
SOURCE: dont know how to empty portable ac amcor AF 12000E
sound like the drain plug needs to be removed
