Question about Amcor PLM-14000E Portable Air Conditioner
My amcor air conditioner is leaking water all over the floor. I drain it and it will only last less then 24 hours till it turns off, leaks all over an needs to be drained. Help!
Posted by rqlshane88 on
madanmarz
    New Friend:
I figured out the problem. My Amcor portable started leaking after the fill light came on for the first time in years. After doing some research I saw that it uses the water to cool some other part of the system to evaporate out the exhaust. So I took the ******* apart and messed with things. Finally I started pouring water into different trays and noticed it would not drain down from the top tray even when running. So I removed the top part and found the drain hole. Blasted that sum ***** with some compressed air and WAMMO it works again.
-madmanmarz
Posted on Oct 26, 2011
okcarltons
    Champion:
  • 230 Answers
Dehumidifying is a product of AC, that is a good thing, water on the floor is not. Do you have the ability to drain the water away to a floor drain or somewhere? Or just drain the catch pan, on what ever schedule it takes to prevent over flow. You obviously have a very high humidity, if your house is tight you should start to see the condensate water slow down.
Posted on Jul 06, 2011
  • 2 more comments
  • rqlshane88 Jul 06, 2011
    Does this product need to be drained daily? Or does it depend on the humidity of the room?
    Also it's leaking from all sorts of spots. If it tilt it forward lt backwards the water just will leak out and not just a drop or two, it pours out!!
    To drain it, we put it put side the window. It's heavy, and is a pain!!! Any easier way?
  • okcarltons Jul 06, 2011
    The relative humidity plays a big part of how much water it will collect, if you drain the pan does it leak, or is it over flowing? If is leaking from where is should not be, leaking not much I can tell you unless its new, then return it.
  • honour21175 Jul 25, 2011
    i went to homedepot with drainage plug and got some tubing..now i have tubing goin to bucket... unit doesnt shut off and no need to try to drain,..just need to empty bucket
My portoable ac is leaking on the floor . am i suppose to have a hose connected to the drain on the bottom in the back of the unit. please explain how i am suppose to drain my machine
a hose is only used for continued drainage in to a floor drain or sump. With out he hose, it's supposed to have a screw in plug to keep the water from flowing onto the floor. Then you would drain it into a low sided container that can hold at least 1 quart of water. Normally, the unit should warn you when it needs draining.
Hope this helped you.
Jul 02, 2011 | Amcor Heating & Cooling
The air conditioner is cooling but it is dripping water on the floor, lots of it, I mopped up more than a gallon for less than 24 hours use.
It sounds as if the drain plug on the back of the unit, down near floor level is loose or missing
Check for that first, because the unit is supposed to shut off automatically, when the drain pan is full. If the plug is leaking or missing, the unit doesn't sense, that the drain pan is full. Also, be sure you exhaust ducts are not bowing down a great deal or trapping exhausted moisture in the duct, that should be exhausted out the window.
Hope this helped you to troubleshoot and solve the problem.
Jun 20, 2011 | DeLonghi PAC C120 Portable Air Conditioner
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner leaks water in side the room. after the drain hose was change and clamped.
I had the same problem. The insulation on the coper line was loose and the pipe was exposed. The water was condensation , not water from the drain.
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Air condition leakes water
you can get a small condensate pump, and run the hose to a drain like a sink or toilet, you may have to trick the switch if you have to put the pump inside, where the bucket would fit.
Jul 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor ALD12000E portable air conditioner shuts down every hour
Is it leaking or shutting off on the overfill?
If it is leaking you have a stopped up drain inside the unit.
jim
Jul 27, 2009 | Amcor ALD12000E Portable Air Conditioner
Water leak
First you have to unplug or "off" the circuit breaker, then install the drain hose.
Oct 24, 2007 | Amcor AL10000E Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
3,468 people viewed this question
Top Amcor Heating & Cooling Experts
Tim Venetis
Tom Chichester
Steve P
Steve P
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
