Sony Mobile 1248-7716 Xperia Play R800a White Smart Ph Android2.3 Ging Logo
Posted on Jun 16, 2012
How can i hardreset r800a?
I fail 20 times on patern mode and i don't have the answer at the 2 questions of the cel?
Ron West
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Oct 22, 2013
Ron West
Contributor
Level 1:
New Friend:
Answers
30
Questions
Helped
5863
Points
37
If I remember correctly the Xperia 800's don't have a recovery mode. Visit the Sony R800 forum at xda-developers. You shoudl be able to find there the flashtool program which you can use to flash a new rom image from your PC.
No check engine light, bulb test good
wow, no jeep stated. nor what year, nor what engine.
ill not even beg country (exports are diffr)
below is all ways, discounting bulb tests.
i guess you mean the key on only self test fails with CEL?
ok the PCM glows the lamp at key on, to tell you the PCM is happy and that it passes its rudimentry self checks
basically means its alive.
if the lamp fails to glow ? (all ways, i fix ECU so know this)
  1. power to lamp dead (fuse ) yes fuses can crack (unseen)
  2. lamp bad, (test it with a battery)
  3. cluster wiring to lamp bad, or that wire from PCM to lamp bad.
  4. ECU bad, yes, some bad ECU's can run an engine.
  5. ECU stuck in backup mode, (think limphome but 2 times worse)
in your case id say bad ECU, or bad wire from ECU to CEL.
no year stated, so is it 1988 with that silly junk RENIX EFI with no working CEL or is the unstated car 1993+ where the CEL started working for the first time?
if 93 or newer, we can connect a scan tool, and scan it.
and see , omg , comms are dead, so ECU is in backup mode.
(backup mode is like lawn mower mode, sure it runs but like crap)
ask? can give vivid details of all modes.....
or comm's is ok, and scans and we see DTCs stored and the CEL status in the scanner says ON,"aka, active CEL"
if it says ON< and is not on, then the wire is bad or the
CEL transistor in the ECU blew up. (common with folks using wrong bulb and overheating this poor transistor) replaced many i have.
there are some facts. and is poorly stated. due to NO YEAR !
retired, ET,
Fog lights don't work. 2006 Kia Rio 5.
Obviously you need wiring diagrams or you can't
work on any vehicles electrical issues
How would someone answer your question ?
The switch you replaced was tested & failed or your
on a Wish & Hope - Push & Poke strategy !!!
What is the code p1388 on the 2002 jaguar v8
P 1388--Variable Cam Timing Over- (Bank 2)
VCT solenoid valve stuck open
Camshaft advance mechanism binding
Need Correct Oil Filter
I will speculate here & say you don\'t run 5W-20 full
syn oil & don\'t change every 4,000 miles since motor
was new
Now you have oil flow issues with the solenoid or failed
cam actuators
6helpful
4answers
LA76931 ICS SERVICE MODE
Keep Volume Zero
Menu>6964 repeat the same procedure 2nd time &3rd time
Again...Menu>6568 (option 4 & more)
LA76931s 7n 58y4 & 59y4
1helpful
CEL P0420 error code Catalytic Converter Issue
That basically is a failed exhaust converter on bank 1,
unless the rear monitor O2 Sensor is bad or both
The car is way too new for that problem
A converter should last 12 to 14 years unless
your engine hasn't run right in years & had continuing
misfires
Don't tell me it has always been well looked after
& maintained,you have little idea what you pay
for these days.
That has nothing to do with the shops you go to,
doing what is necessary over the years to solve
issues. They fail miserably, because they are not
proactive & look for issues.
70helpful
5answers
Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL Fuse Position Rating Circuit Protected 1 7.5 Amp Power Mirror 2 — Not Used 3 15 Amp Parking Lamps 4 10 Amp Left Headlamp 5 10 Amp On Board Diagnostic (OBD) II System 6 7.5 Amp Air Bag System/Blower Relay 7 7.5 Amp Illumination Switches 8 10 Amp Right Headlamp/Fog Lamp System 9 10 Amp ABS System 10 7.5 Amp Speed Control/GEM System/Brake Interlock 11 7.5 Amp Warning Lamps 12 10 Amp Front Washer System 13 15 Amp PCM System/Stoplamps/
4WD/ABS/Speed Control 14 10/20 Amp ABS System 15 7.5 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 15 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 7.5 Amp Radio/GEM System/Anti-Theft 21 15 Amp Hazard Lamps 22 10 Amp Turn Signals 23 — Not Used 24 10 Amp Starter Relay/Anti-Theft 25 7.5 Amp Speedometer/GEM System 26 10 Amp 4R44E/4R55E Trans./Backup Lamps/DRL System 27 10 Amp Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys. 28 7.5 Amp GEM System 29 10 Amp Audio System 30 — Not Used 31 — Not Used 32 — Not Used 33 15 Amp High Beam Lamps 34 — Not Used 6d47eae.gif
Top Sony Mobile Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Sony Mobile Cell Phone Expert? Answer questions, earn points and help others
