20 Most Recent
Sony Mobile 1261-4451 Xperia P Lt22i Smart 16mb Black The Ultra-Bright Questions & Answers
Display Lock
Press and Hold together: Power Button + Volume Up Button to go into service menu. From here you can do a factory reset. This will erase all your personal data!!!
How do I UNlock my screen locked phone
Press and Hold together: Power Button + Volume Up Button to go into service menu from where you can do a factory reset. This will erase all your personal data!!!
Album not working
its because of software fault you just restore it and the problem will be fixed.
Xperia p restarts everynow and then
My dear::":""mY Dear:First:restore your Phone SettingsIF problem not Solved So Secend Option:Please Format Your Phonewe can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.*#7370# or *#7780#Default security code is 12345release some memory then it will b opened your phone or memory card get attack by virus. pls do a format phone and memory card.If Problem Not Solved SoVery Best Solution:flash new software install in the phone problem will solved quickly
Troubleshooting stanley bs16bs
This could be due to several reasons such as a faulty battery, a problem with the charger itself, or an issue with the connection between the charger and the battery. Here are some general steps you can take to troubleshoot this issue:
Check the Battery: Ensure that the battery you're trying to charge is not faulty. If possible, try charging a different battery with the same charger to see if the problem persists.
Check the Charger: Make sure the charger is functioning properly. If you have another charger, try using it to charge the battery.
Check the Connection: Ensure that the connections between the charger and the battery are secure and clean. Any dirt or corrosion could interfere with the charging process.
Reset the Charger: Unplug the charger, wait a few moments, and then plug it back in. This can sometimes resolve minor technical issues.
https://www.manua.ls/stanley/bc15bs/manual
If unresolved, you might contact Stanley customer support.
4/18/2024 3:05:03 PM •
Cell Phones
Answered
Yesterday
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
2 days ago
