2004 Chevrolet Avalanche Logo
Posted on Dec 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver door problems
While driving the computer console says the driver door is still ajar when its closed. it wont stay locked while driving and the other doors will. And also the computer keeps dinging and alerting that the door is open while driving. when you turn the car off and use the keyless remote to lock the car, it locks but the factory alarm wont turn on.
Paul Thoegersen
Level 2:
  • Expert 95 Answers
  • Posted on Dec 02, 2008
Paul Thoegersen
Expert
Level 2:
Answers
95
Questions
0
Helped
65119
Points
282
There is a micro switch in the door latch thats faulty. I believe you must replace the latch assy.
Peugot partner mpv 2002,door ajar warning on all time central locking bounces/wont stay locked and door ajar buzzer sounds with rh indicator...HeLp
check all of the door sensors. (buttons that are pushed in when doors close) they sometimes come loose and need adjusting.. easy fix once you find the bad one.
1helpful
97 lincoln town car door ajar stays on and reading lights wont go out when driving what can i do all doors are shut
unhook your battery for 5 mins then hook it back up go to each door and open and close one at a time that way you know which door is having the problem once you find that out replace the door switch and problem fixed or just dont open that door.
I have a 1997 jeep grand cherokee limited edition. The Computer is dinging and reporting that the drivers door is ajar, when it is clearly closed. The lights come on as a result of this computer issue...
Locks should be tesed /checked via hand terminal(which dealer have).
sometimes that VIC module creates problems due to badsoldering points on its circuit board. try to resolder them. but sometimes it shows what is reads from sensors around car. like tail light out or door is ajar signals.
there is a possibility that switch checks the condition of door which is actully bad and this makes auto lock system act like door is not closed and wont allow it to be left as locked position. this is looking like a endless loop.
1helpful
2003 ford explorer driver side door lock keeps opening and closing. interior lights stay on while driving
Interior Lights - Check door ajar switch, its possible that go to bad.
Door Lock - Check ground connections and test switch.
Rare but possible, re-synchonized security module.
1helpful
I got a mercury.. and the problem is the driver door some time it locks good all the way while start driving will lock, just like any other car. and some times it wont lock u can still drive but it will...
Your door ajar switches are located inside the rear faces of each door along with the latches. Just liberally spray a petroleum based lubricant into the door latch areas of each door (one at a time) and open / close the door several times. Once lubricated, your door ajar light, interior lights, and autolocks should function properly.
Good luck.
Door ajar light comes on
The door lock relay or one of the door sensors/ switches is defective.
2helpful
"Door Ajar" signal on dash panel stays on even when doors are clo
there should be a switch mounted( or more than one) in the door jamb that tells the car when the car door is open...i will probably look like a little plastic plunger...might be broken off or bad internally
Door lock staying locked so door cant clamp on to the striker
Hello and welcome to FIXYA, it sounds like you have two problems, first the door ajar switches in your truck are sticking, and causing the ajar light to remain on, and second the door lock actuator is shorted and getting stuck in the lock position. To repair the switches, obtain a can of brake cleaner and spray the door latch of each door for about 3 to 5 seconds, then open and close the door 10 times to work the cleaner into the switches. To fix the lock problem, you must first pull up on the knob in the door panel to unlock it. Then remove the door panel, and replace the door lock actuator.
31helpful
3answers
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
3answers
Interior lights wont shut off?
sounds like door switch is bad
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
