Saysremove memery resident programs or unecisary utilitys then shuts off what can i do
Windows Vista is a huge resource hog, if you have windows XP load in DVD tray, power up, wait for sony logo, press F12 or assigned number on lower right on logo, use arrows on the keyboard to toggle up or down, high light CD/DVD driver and press enter, this will automatically load windows XP and follow prompt.
SOURCE: computer wont turn on
When you end up with a registry corruption, you are limited to what you can do. First thing I would try is this. When you power your system on and immediately after the POST boot, begin pressing F8 on your keyboard. This will bring up a Windows Boot Menu. One of the choices you will see if, "Last known Good Configuration..." If an install of software is what corrupted your registry, this should hopefully undo that. If you are experiencing hard drive failure, this will probably not fix that.
If last known good configuration does not work, I'm afraid that the only other solution is going to try and do a parallel installation of Windows so that you can save your existing data.
What Operating System are you using?
Here's microsoft's official description of your stop error:
http://support.microsoft.com/kb/830084
SOURCE: system crash after upgraing memory for acer aspire 4315
If u have 2 ram in 1 computer memoryh frequence
conflict betwwen each other if both r differ.
So cheange yhour ram and check both rammeoroy frequence are same .
SOURCE: memory dump
please try but thts for sure tht u dont use the dump files
http://cupersoft.com/privacyeraserlib/plug-ins/plugcomment/plug_name=Clean%20Windows%20Memory%20Dump%20File.html
SOURCE: packard bell versa e400
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Hope this helps. Please rate my response.
Thanks.
Have a good day
im using vista and am going to d.g. to xp if i can get in
