In the passenger compartment fuse block look for fuse number 42. That will be the left trailer stop/turn fuse.
fuse 36 is the right stop/turn fuse.
they are both 10 amp fuses.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: rear brake lights don't work
you prob got a trailer plug prob bad wires if not tail lights run through turn signal switch tell fix ya bout me ok
SOURCE: trailer towing fuses
Battery junction box (BJB) fuse(s):
SOURCE: LEFT TRAILER TURN SIGNAL DOES NOT WORK
I have seen once before that the fuse box was bad on a 2003 Dodge 3500. I had power in and nothing out. We had to replace the box. Not cheap! Hope it is simple like a loose connection though. I think I had to pull the inner fender on the drivers side to access the bottom of the fuse box. Pain in the ****, but...
SOURCE: Factory Trailer tow package - fuses?
Look in the owners manual first. I have seen some of the fuse boxes under the back seat on the drivers side. Also try http://www.etrailer.com/faq-wiring.aspx. This should help. Mike
SOURCE: 2004 ford f150 no tail ights ,no left turn signal
Check with http://www.etrailer.com/faq-wiring.aspx. They may have the fuse location. I know some are behind the passengers kick panel. Hope this helps. Mike
