Computers & Internet Logo
Anonymous Posted on Jun 03, 2012
How do I get into bios
How do I enter bios
Roger Faucher
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 35 Answers
  • Posted on Jul 22, 2015
Roger Faucher
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
35
Questions
0
Helped
5488
Points
92
As soon as the Fujitsu logo appears on the screen, press the F2 key. If this doesn't work, please post the specific family and model of your Fujitsu Siemens LifeBook PC.
Thanks,
Roger
tip
How to enter bios in dell laptop
Applicable To:
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
Related Topics
How to access bios in Acer
How to access bios in Dell
How to access bios in Compaq
How to access bios in Emachines
How to access bios in Fujitsu
How to access bios in Gateway
How to access bios in Hp
How to access bios in Ibm
How to access bios in Lenovo
How to access bios in Micron
How to access bios in Nec
How to access bios in Packard Bell
How to access bios in Sharp
How to access bios in Shuttle
How to access bios in Sony
How to access bios in Toshiba
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Power but no display
try going into bios blue screen press f2 or f10 or f12 on start up beep . change setting in video settings
  1. Watch for a "entering setup" message in the first few seconds after turning on your computer. This message varies greatly from computer to computer and also includes the key or keys you need to press to enter BIOS.
    Here are some common ways you might see this BIOS access message:
    • Press [key] to enter setup
    • Setup: [key]
    • Enter BIOS by pressing [key]
    • Press [key] to enter BIOS setup
    • Press [key] to access BIOS
    • Press [key] to access system configuration
  2. Quickly press the key or keys instructed by the previous message to get into BIOS
Bios password
Hello katsdre.
This should work.
open your bios , go to security,
choose, change security password
enter "your" password >press Enter
for the new password enter nothing just press enter twice.
message " password changed" should appear.
leave bios with save changes and restart.
LG. Gue
Bios password on toshiba
Some Toshiba laptops come with a system BIOS password, making anyone without the password unable to get past the BIOS screen at system startup. This is a strong security measure, as it renders a stolen computer useless unless the password is known. If you have a Toshiba laptop and want to change the BIOS password, you can quickly do it.
1. Power on the computer while holding down the "Esc" key. Enter your current password when prompted and press "Enter."
2. Press "F1" to enter the BIOS setup menu. Highlight "REGISTERED" with the arrow keys and press the space bar. Enter your password and press "Enter."
3. Restart the computer while holding "Esc" and hit "F1" again to enter the BIOS menu. Highlight "NOT REGISTERED" with the arrow keys and press the space bar. Enter your new password and press "Enter." Type the password again for verification and hit "Enter." Press "End" to save the changes, and "Y" to exit.
I hope you find it very helpful. Best regards.
Remove toshiba password from bios satellite 3000-x4
The Basic Input/Output System (BIOS) password is not set by default on Toshiba laptops. When set, the BIOS password must be entered every time you turn on your Toshiba or wake your system from Standby mode. If you forget the password, you cannot boot your system. Prevent having to enter a password or the results of forgetting the password by removing the BIOS password from your Toshiba laptop. Other types of passwords can be set, such as a Windows password, to prevent unauthorized access to your machine.
1. Turn off your Toshiba laptop.
2. Wait 30 seconds and turn your laptop back on.
3. Press "F2" repeatedly as soon your Toshiba laptop begins booting until the BIOS menu screen appears.
4. Enter your existing BIOS password and press "Enter."
5. Press "F2" again to enter the BIOS, if prompted.
6. Use your arrow keys to select the "Security" tab in the BIOS menu.
7. Use the arrow keys to select "Set User Password."
8. Press either "F5" or "F6," depending on your Toshiba laptop model, to open the Password section.
9. Enter the current password into the "Old Password" prompt and press "Enter."
10. Press "Enter" when the "New Password" prompt appears. Do not enter any text in this box.
11. Press "Enter" again to confirm the new password.
12. Press "F10" to save your changes and exit.
2helpful
2answers
How to enter bios
Hi...
To enter bios it so easy. When you turn on your computer you just only press delete to enter bios. If the bios does not exist you can press also F2.
Regards
PCmania
2answers
How to set the security lock in laptop
plz specify the model and make
and also specify if it is a physical lock or the lock on your windows
5helpful
2answers
Bios reset
As another option you could try resetting the jumper. Some boards save the password regardless unless the reset the BIOS by using the resetting jumper. Refer to the motherboard's manual for further information on how to do this.
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
