Xerox DOCUMATE 510 Flatbed Scanner Logo
Posted on Nov 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Scan is faded in center of scanned documents
The center portion of scanned documents is faded and almost not readable. horrizontal lines disapear in center of line.
L Pfaff
Level 3:
Top Expert:
  • Xerox Master 11,573 Answers
  • Posted on Aug 27, 2016
L Pfaff
Xerox Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587876
Points
181713
Mohan Sriraman
Level 2:
  • Expert 490 Answers
  • Posted on Nov 28, 2008
Mohan Sriraman
Expert
Level 2:
Answers
490
Questions
0
Helped
247112
Points
823
Try cleaning the glass with IPA (Iso propyl alcohol _industrial grade is enough) Dont use any solvent or petrol.
S. Mohan, Chennai, India
EPSON XP400 SCANNED IMAGE FADED B&W OR COLOR
try to reinstall drivers or try to scan connected to other pc, if problem remains, scanner is done
1helpful
Scanning is backwards
I just got my scanner yesterday and had the same problem with my FIRST jpg. I looked for a solution and found your posting. I had scanned one page of the instruction booklet from the center fold outwards, not in the direction of the text, but rather sideways across it. That image was mirrored. I did another scan in the 'proper' direction, that is, from the top of the page to the bottom, both as a jpg and a PDF and they came out in a normal, readable form. Perhaps you need to do it a few times if you haven't already? Have you tried calibrating it?
How to remove a green line appearing near the taskbar portion of my laptop
A. Please try this: Please start, in the search box type msconfig and hit enter on the keyboard. You will get System configuration utility. Please click tab, startup and then click Disable and then click OK. Restart your computer.
B. To remove malware/adware/spyware:
Please scan your computer using free version of Superantispyware.
http://www.superantispyware.com/
Please run quick scan.
When I scan to printer the page comes out with short lines down 1 side
If your printer has both an automatic document feeder and a flat glass portion for scanning, try scanning from both. If you only get the lines on one of the scans then that is where your problem is. Most common issue on scanners is a liquid paper, bit of paper, glue, etc on the Automatic document feeder glass. Clean the glass and you should be fine.
Line appears on scans and faxes
Do you use the document feeder when faxing and scanning? If so, the line is likely some paper dust, white-out, or other dirt on the thin piece of glass to the left of the main platen glass. Wipe that glass strip with a lint-free cloth, and if that doesn't work try using a little bit of alcohol.
If the line persists, or it occurs when you don't use the document feeder, it's probably dust somewhere in the optical portion of the unit, underneath the glass. If you want to take it apart, you can blow some compressed air around down there to scatter the dust or try wiping down the mirrors with a lint-free cloth.
Uneven black border showing up on scanned documents
Most scanners scan the whole "bed" not just the document lying on it. Where no part of the document covers the bed usually appears as black.
Normally when scanning you are offered and option whether to scan the whole document or a portion thereof. When previewed, a dotted line appears around the portion the scanner thinks you want, you have to re-arrange that box so that it lies just within the part or the document you require.
Should this not resolve the issue the menu options on
the left hand side of the Xerox web page should guide you to a resolution.
http://www.xeroxscanners.com/en/us/products/DM632/
Copystar cs-c2520 i have a faded line down the center when i copy only not when i print or recieve a fax.
Either a problem with the document feeder or something on the glass. If it's faded it may just be a roller not pushing the paper onto the scanning area properly.
1helpful
Trying to scan and then attach as document an 8.5 x 11 paper
Usually there will be a dashed line that is around the image. Sometimes it will just surround a darker portion of an image, such as the text portion on a white piece of paper. This is common. Use the mouse and aim it at the dashed line and "pull" the lines to the edges of your document, then press accept. This should fix your problem.
1helpful
2answers
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
