I would suggest plugging it into a wall charger for at least an hour to see if it was a weak battery.
If that does not help try connecting it via it's USB cable to a PC - this sometimes sparks it into life.
If not go for the soft power reset. (Hold the power button for a slow count of 30, release. Tap to turn on.)
With the display crystal cracking there very little to repair it that I know of. Try contacting a business that that replaces the Iphone and ipad screens. They may have a source of supply for the part(s). If they can not assist please find below a link to the customer service page of Kobo. Fill it in and ask about repair/replacement of the screen of the reader. If there is still a problem please come back and we shall see what can be done.
Thanks
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
I have vox mini laptop and I want to hard reset it but I can't do because in my mini laptop not a + nd - buttons so plz tell me how do I reset with any other mathod.
you will need to connect your Kobo Vox to your computer
click start click on computer to open you should see your drives C: and your other drives cd dvd and your Kovo Vox drive E: or F: it might be seen as a mass storage device from there youselect the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them tousb drive then drop themexample on how to safe data/files to a usb drive click start all programs accessories open windows explorer navigate to your data right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it a browse option will open you can save it into a folder in my documents or another device or a usb device if you need more help with this post a reply hope this helps
charge portal pushed into kobo
