How many watts are in Welbilt Microwave model 0024337 manufactured in July 1991. This model has turntable and defrost cycle
SOURCE: WATTS
The output power is 1000W and that's near the high end for a consumer microwave. Hope this helps.
Please write back with more details if you need further help.
We do appreciate your very thoughtful rating of our answer.
SOURCE: No turntable, no heat. Light, vent fan and keypad all work...
That would be a problem with your primary interlock switch or its mount.
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The interlocks are highlighted in the diagram below.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they
have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like
this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift
replacement for a missing tray. You have to find a saucer that fits
securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your
SOURCE: Can't pop popcorn well
It's 850 Watts, 0.9 cu ft.
That's enough for popcorn, but a magnetron does lose power once it starts to age.
The figure I've heard is an average life expectancy of 2000 hours for a magnetron.
Two "Band-Aid" suggestions for better exposure and more even heating:
1. Place the popcorn bag on top of an upside-down paper plate.
2. Place the bag off-center instead of dead center. Placing food in the center of the turntable is not as efficient as placing it off-center.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: I Can't Find Microwave Glass Truntable Tray for Jenn-Air
Martin Microwave has one in stock here for $25.99.
I searched for model JVM8000 and this came up.
On a related note, I think that what Smithbrother was talking about is something like a Micro-Go-Round. Here's a related post from my "Ask Mr. Microwave" page.
Q. My turntable is missing or
unavailable. What can I do?
A. This sort of
arrangement can be a good temporary fix until a suitable replacement
tray can be found, or even a permanent solution.
Place a microwave-safe saucer upside-down over your
roller ring / turntable support assembly. Then place a microwave-safe
plate rightside-up atop the saucer.
Be sure both are centered, checking them frequently
to be sure shifting does not occur. Otherwise, a spill of hot material
could result. Safety first!
Another option is to check Wal-Mart and other
stores to see if they have a Rubbermaid or Nordic Ware wind-up
turntable such as the Micro-Go-Round.
We're
thoughtful rating of our answer.We're
check your manual, it should be there. Find Welbilt Breadmaker manuals here:http://manualfox.com/link/welbilt.htm
That looks like the serial number.
Can you check the tag again for the model?
