I couldn't find a replacement fuse for my Manning-Bowman coffee maker, so I repaired it. The fuse consists of three parts: the square end pieces and a rectangular connecting piece between them. (They all look like brass.) They're soldered together, and when the pot gets too hot (as it did when I plugged it in before adding water), the solder melts and the connecting piece drops out, shutting off the pot.
To repair the fuse, you'll need solder, a soldering iron, flux, and a small brush. You can get these supplies at a stained glass hobby shop. Leave the end pieces in place and put the connecting piece between them. Brush a little flux on the pieces, heat the solder and put a bead between the connecting piece and each end piece. Let cool and clean it.
If it's a standard style fuse, I would think any department store, hardware store, appliance parts store, or even grocery store would have them.
If it's a special type, you probably have to call a local appliance parts store or contact the manufacturer.
If you don;t have your owner's manual, you should be able to get their contact information from the dealer you purchased it from.
I have not been able to find the fuse at any local appliance parts store. Apparently it is not a common fuse?
