Remove the Battery from the Battery Compartment. Remove the small panel cover. (Access Door)
Right there.
http://support.dell.com/support/edocs/systems/wsM70/sm/index.htm
Click on Coin-Cell Battery.
Regards,
joecoolvette
(Make sure the AC adapter { Charger } is not plugged into the laptop)
SOURCE: how do I reset my lost bios password for Dell
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
SOURCE: resetear bios
Si se ha olvidado la contraseña del BIOS, you' necesidad del ll de entrar en contacto con el soporte técnico en Dell para resolver la contraseña
SOURCE: dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
SOURCE: how to break bios password for dell precision m70
The password exists to prevent a THIEF, in possession of your laptop, from "breaking-in" to the stolen laptop.
As such, find the original bill-of-sale, to prove your ownership, and contact Dell's Technical Support, and get them to assist you.
open ram cover u will see the small jumer gold color just short it with flat screw driver .. thanks
