Toshiba Regza 32LV67U 32 in. LCD HDTV Logo
Posted on May 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keeps telling me to scan for channels
Not sure how to scan for channels
Anonymous
Level 3:
Top Expert:
  • Toshiba Master 14,553 Answers
  • Posted on May 20, 2012
Anonymous
Toshiba Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718898
Points
48227
Most sets its done in the setup menu--select if cable or antenna and then select auto program, set will scan and store all available channels it can find.
How to reset channel auto scan.After I finish channel scan,message pops up stating PLEASE RUN CHANNEL AUTO SCAN,
If when You scan, and you don't get at least one channel, it will keep showing You this message! look at screen it will show new channels! if no new channels check to make sure your coax is hooked up good, also make sure you are using right setting if outside antenna, select antenna, if cable select cable for your source!
My tv keeps telling me to run a channel scan, how do you do this while using a Direct tv remote?
I'm not sure why your TV wants you to do that, but you would have to use the TV remote. You're Direct TV box is responsible for your channel lineup, and I would be using the component or HDMI connections to get the best picture, not the RF or coaxial connector.
My screen keeps telling me to auto scan channels?
This is for basic cable TV. If you have basic cable, go ahead and let it scan channels. If you have digital cable or anything else and use a INPUT or HDMI or RCA to watch TV then just ignore the scan channels prompt as you have a cable box that handles all that for you.
Keeps telling me to run an auto channel scan
Check and replace its main system control memory IC. It is faulty. It does not hold the data. Gopakumar Gopalan Google
1helpful
The channel won't change and keeps telling me to perform an auto scan
well, did you perform the auto scan? the auto scan "scans" through channels and needs to be done.
1helpful
Channel scanning fucntion won't work on my new Oregon Scientific TP329 Two Way Radio. Keeps scanning without finding a valid signal. The radio works when I set the channel randomly but so far I can't find...
Make sure there is a transmitter "on" somewhere along the way, otherwise it would not stop scanning. Try keeping the PTT pushed on the other set whilst you scan.
Freeview box
After scanning the box should save the channel automatically. If the box does not save the preset after scanning channels, then it is probably faulty.
Some box has a pinhole reset button at the back, if you have this reset button keep it pressed with a pencil for 10 seconds to reset the freeview box.
If it does not work, the nbox is probably faulty.
With freeview you only pay for few scrambled channels, the most of them are free and do not need any additional fee.
Freeview is not available in all areas, check that you have freeview in your location, and that aerial is well connected to the box, otherwise not finding channels is normal.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
