it get freezed i ve ended the process and tried for another couple of tyms even yahoo 8.0 is showing an errorit get freezed i ve ended the process and tried for another couple of tyms even yahoo 8.0 is showing an error
yeah , me, too...same problem...tried removing some soft ware that i might cause the problem but ...nothing works...pls help yeah , me, too...same problem...tried removing some soft ware that i might cause the problem but ...nothing works...pls help
have the same problem here... can somebody please offer some solution...
AnonymousJan 30, 2009
I had installed yahoo messenger 9.0 ver on Windows XP. Suddenly the yahoo messenger stopped working one day and when I tried to remove/reinstall it would simply hang.I had installed yahoo messenger 9.0 ver on Windows XP. Suddenly the yahoo messenger stopped working one day and when I tried to remove/reinstall it would simply hang.
AnonymousApr 08, 2009
its not installing after 99%
The application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.The application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem.
AnonymousMar 28, 2014
i've done every trouble shooting thing ever and nothing i do gets it to work. i've trying vcosing everything, turning off my security etc etc.. you name it, i've done it. HELP!i've done every trouble shooting thing ever and nothing i do gets it to work. i've trying vcosing everything, turning off my security etc etc.. you name it, i've done it. HELP!
You can't post conmments that contain an email address.
Yes,delete the previous setup pf your yahoo messengr,after that download new setup yahoo's official web site and re-install it ,your problem will be fixed!!!
There comes error in Yahoo messenger installation, some versions don't compatible with OSs like xp, windows 7. so you only need to remove the setup and again install it through this place - http://messenger.yahoo.com/. I sure your problem will be solved. before installing see the details of the version and compatibility with your computer;s OS. Thank you
try to install a newer version Windows Installer , allow the yahoo installer on your firewall or temporarily disable your security features and try to install yahoo messenger again.
in this u can do one thing
uninstall the anti virus install on the PC and the uninstall and reinstall yahoo messengar and try to access it and at last install the antivirus
ok first of all install an latest & updated version of antivirus and scan all the system throughly and delete all browsing history and in the temp dir
start>run>type --- %temp%
and delete all files in the folder of temp
install the latest ver of internet Explorer V8.0
and install the latest yahoo messanger from the site \\\\i hope so it will work
Yeah it been a problem for so many others like you, check out this official solution at YMessBlog
But I recommend to you install a standalone version ;
A standalone version is a full complete installation of Yahoo Messenger ,which doesnt connect to internet for further installation of the software.
So download the latest Yahoo Messenger from here at softpedia
This is a ambiguous error with the new Y! Messenger 9.0 as stated by the messenger team here: http://www.ymessengerblog.com/blog/2009/01/20/trouble-installing-yahoo-messenger-90/ . I would just go download 8.0/1 or even better go with open source and get Pidgin ( http://www.pidgin.im/ - great piece of software). The messenger blog says they need contributions into fixing the issue. Good luck.
yahoo messenger 9.0 was not loading for me....so i tried to re-install it..tht ddnt work...thn i deleted all the files manually and removed the program... but now wen i install it it stops at 99%..i saw somewhr a suggestion...it helps to reach 100%but again the loading prob.. so in short nothing worked out.. i tried several times to install... it stops at 99%.... YAHOOOOOOOOO plzzz help. i use windows XP.
cannot install yahoo messager
It loads til like 100% and then it says "ABORT OR RETRY".
i tried downloading flash cuz someone else said to do that and no luck!!
