The battery & clock icons are flashing on my D50 top monitor. I've tried using three different batteries including one new one. Doesn't appears to be the batteries. The camera won't function. The owner's manual that comes with the camera suggests the internal battery that powers the clock needs to be recharged and the clock reset. How do you do this? Do i need to buy a DC charger? The rechargeable batteries don't seem to be doing the trick. HELP!!!
Unable to show the menu, the top screen does not
clock and the battery symbol flash for a short period and then the f stop and the shutter speed disappear but other info stays. I have replaced with a new battery but
Well i had only the clock icon flashing and after setting the date and clicking an enter on it disappeared my battery icon's all good...about the battery thing i would recall what happened before the icon started to flash might be helpful maybe the inner spring got a damage or the upper sheet metal or membrane as you please has something... cause it happened to me couple of years ago but it got solved and i cannot remember how sorry...definitely there is an easy solution cause i had not had to take it anywhere...
D50 Battery & clock icons Flashing
&Card sing flashing in the Weive finder
my email ID [email protected]
Same here
im having the same issue. Can't use the camera at all. I tried to reset the camera using the small button located at the bottom of the body. No luck!!!
Exactly the same problem. Don't want to send it away to be fixed. Help someone!
Same problem here...resets do not seem to be working.
