That isn't something that can be guessed at on the internet
You have had many things replaced already,necessary or not
& some testing done as well
I assume you paid someone to do that & only having a repair
shop with the experience on your type vehicle will be able
to find the issues
The internet is a good place to find & learn some things,
but you have taken the repair shop approach, as a result
of the complexity of sovling the issues & I wonder why
anyone would feel someone would be able to guess at
any vehicle issues without the vehicle to test.
Vehicles for the last 30 years can only be fixed in a repair
shop or dealer. There are to complicated. Without all the
electronics,you could probalby solve most problems in
your driveway
SOURCE: 93 accord stalled while driving....
pull one of the plugs out leave the plug wire on it and rest it on something metal on the car and have someone try to turn it over.if no spark can be seen try changing your crankshaft sensor
SOURCE: 96 model hyundai excel stalls
we had a hyundai once, that stopped and started for no apparent reason , after much looking at and mechanics it turned out to be some butterfly or non return valves leading from the fuel pump to the engine. they were closing up and stopping fuel from passing through , might be the same kind of thing . hope this helps
SOURCE: 1999 saab 9-5 stalls without warning won't restart for 30-40 min.
Hello.i had similar problem.replaced ignition coil+cranksensor,driven it for several months now.a.ok.
SOURCE: motor stalls when driving then starts and stalls right away.
Replace the distributor's magnetic pickup located inside the distributor surrounding the distributor shaft, the only other thing thankfully on this ignition system if memory serves me on the f 150 straight six 300 cu inch is the dura spark ignition control box, of course do the obvious tune up parts replacement dist.cap rotor,plug , sparkplugs before spending the $40.00 - $50.00 bucks on the dist.. pick up, you may have a weak a fuel pump check for adequate fuel pressure at carb 7 - 10 lbs.
SOURCE: 1994 dodge intrepid 3.3l stalls while driving w/o
I have a 1995 Dodge Stratus and I had the same problems last winter it turned out to be the main brain the ECU as they call it It costas about 1200 dollars new but i scored mine from a junk yard for 10 bucks and my car hasnt done it since. They very well may be your problem because i have the same engine in my car its just a smaller body style. look on the net for spaldings used car parts u can look up parts and they usually sell ecus for 75 to a 100 dollars.
Testimonial: "thx for input !"
