Both the MTX8000 B5 & B7 models are Type II Trunking. If you are (un)lucky enough you might find an F3 modem that does Type II.
If it is an MTX8000 and has a front mounted display with either a 6 button or full keypad, you have a radio that will do Type II.
There were a few B3's that were Type II produced by Motorola. However, you can clone a Type II code plug into a B3 radio and it will work just fine.
You can run system watch using a MTS2000 handheld. Firmware version has to be above 5.44 (which has a 512k controller in it). Most MTS2000/MTX8000's only have a 256k controller, which will not work. You can put the radio into RF modem mode from the F4-F4-F4 (Trunking Config).
NOTE: When the radio is in the RF MODEM mode, it will do a self test and then the screen will go blank. The radio DOES NOT have to be programed to the system you want to watch. You set SYSTEMWATCH to the Spectra with RIB mode (works best). Even watches Type I systems.
If you have the accessory adapter for the side connector on the radio, the typical schematic of the speaker mic looks like
this.
If you are using a Public Safety speaker mic with the radio, you might want to order part number 3205514W01 to cover the antenna connector on the radio.
If you are trying to program a MTX-838, from what we've heard, you need to use the MTSX software. The RVN4097F ver R02.10.01 RSS package specifically shows it programs the following radios: MT/MTS2000 MTX838/8000/9000. Now, the update for this software is RVN4097M R06.00.00 05 Sept 97, which should mean that it should program the radio as well. The cable you need is the standard
MTSX programming cable.
Do you want to build your own programming cable? If you don't want to use an old speaker mic cable, see the individual part numbers of the parts for the Service Cable, below.
You may want to look at the schematic for the
RKN4035D Service Cable. This is the actual Motorola cable used for programming and servicing these radios.
The individual part numbers for the components of this cable are listed below.
Reference
Part Number
Description
C1
21-84008H06
Capacitor, 33nF
09-84538E03
Receptacle, 25pos
15-80349B36
Housing, Connector
30-05118W01
Cable, 13 Conductor
01-80754A26
Plug Assembly
5
42-10217A24
Strap, Tie
6
38-80373B24
Protective Cap
7
04-10058B12
Washer, Nylon
8
42-05184R05
Strain Relief
9
22-05541V01
Pin, Latch
10
41-05538V01
Spring, Latch
11
55-05536V01
Latch
12
15-05691W08
Housing, Connector
13
32-05533V01
Seal, Baseplate
14
32-05472P11
Gasket, "o" Ring
15
64-05241X01
Baseplate
16
39-05895V04
Contact, (13)
