If you have a white line on screen---middle that runs left to right it is a vertical circuit problem.
This can be a easy repair: The set uses a chip---usually 7-13 pins in a straight line package-----a lot of these sets the solder from heat breaks loose and all that is needed is to resolder the pins on that chip.
A hint: usually a good solid rap on the top or side will in this case try to make the picture open up.
You need to be able to get to the part and solder.
use the make a comment button if you have questions or need more help.
