Poulan Pro Chain Saw 46cc 20" Logo
Posted on Nov 21, 2008
My chain saw
How to replace hose on saw.
  • Anonymous May 11, 2010
    are you speaking of the Fuel Lines??
Anonymous
Level 1:
Problem Solver:
  • Contributor 3 Answers
  • Posted on Jan 28, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
2164
Points
You need the correct size line, it comes new yellow colored now , claimed to be more impervious to gasahol -with a razor blade , cut the end of the new hose on a long enough angle to feed it thru the tank grommet, then you can grab it thru the tank grommet with medical locking forceps - its a snug pull thru the grommet but easy - hope this helps
Why does the gas intake hose keep coming off whenever you prime it?
Some fuel types are very aggresive and will attack the material the hose is made of, the only answer is to replace the hose, and if required use a small clip or tie strap around the hose connection to ensure it does not come off.
My model 50 saw will work for about one minute then stops as though the fuel was turned off . if iwait for 5minutes it will start again any ideas would help me
Start by removing the hose from the tank and replace the filter on the end, check the fuel hose up to the carb for signs of cracking, or fuel escape, if so replace the hose, if no better, try slackening the fuel filer cap when the saw sarts to die, if it picks up again you need to replace the fuel tank breather.
1helpful
Hi...I have a Poulan chain saw 2000. I can not
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1b4ef1f00fa5e65888256bfa0019583f?OpenDocument
Did you replace the hoses? It only needs a pin hole. This is older than dirt! I can say that, I have a XXV. There should be an impulse line from the crankcase to the carb somewhere, it may be bad. Crank seals may be leaking. Maybe time to spring for a pressure diagnostic by your friendly local Stihl shop. HTH
Lou
2helpful
The chain locked up with the engine running. noticed no oil in the oil chamber. what needs to be done?
The bar and chain got very hot. Try this:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up.
  2. PUT ON GLOVES; completely remove the chain from the bar. Hold the bar horizontal and install the chain in the upper bar groove, (mark one of links) rotate the chain one complete revolution. If it rotates freely without catching or riding up in the groove you can reassemble your saw try it.
If my saw I would seriously consider replacing the bar and chain but I cannot see what damage has been done. HTH
Lou
3helpful
How do you replace the gas line on a McCulloch chain saw? When I try to pull out the filter the line broke. chain saw
use a pair of long needle nose pliers to get the filter out then fish the new line threw the hole and put filter on the end o of the hose and pull it into the tank with it laying in the bottom, then cut the hose and slide over carburetor.
2helpful
2answers
My husqavara saw wont oil tthe chain .. what should i do
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
10helpful
The chain saw is not oiling the chain. NO oil is coming out. It is not reaching the bar.
Oil System Plugged.
Lou
1helpful
2answers
Chain saw does not get oiled?
Oil System Plugged.
Lou
Oct 05, 2009 • Garden
1helpful
Hi i have a bahramshahr chain saw and cant get oil to lube the bar, ihave traced the hose and made sure its not blocked and its all clear .are these gravity fed or does it work on venturi action , or does...
I dont know this saw but most saws have a pump
mounted behind the chain drive. On most saws it is not too dear and easy to replace. Stephen
Aug 09, 2009 • Garden
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
