Need to reset pass word for my computer acer extensa 5420
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
SOURCE: my acer 5420
you need to download an updated driver for your acer 5420 or go to the website for the pro stick manufacturer and update the latest driver for their stick. start with your drivers and make sure you get the correct one for your model. this should resolve future issues with driver conflicts on removable media. which is the problem you are having.
Good Luck!
Ruben
SOURCE: My acer extensa 5420 will not power on. The
Hey FED32, does it make like a clicking sound when you attempt to start it up, it makes it maybe 2 or 3 times then shuts off. does the first green led light up and then shut off.
SOURCE: forgot BIOS password for Acer
Every system must store the BIOS password
information somewhere. If you are able to access the machine after it has been
booted successfully, you may be able to view the BIOS password. You must know
the memory address where the BIOS password is stored, and the format in which
the BIOS password is stored. Or, you must have a program that knows these
things. You can write your own program to read the
BIOS password from the CMOS memory on a PC by writing
the address of the byte of CMOS memory that you wish to read in port 0×370, and
then reading the contents of port 0×371. !BIOS will recover the BIOS
password for most common BIOS versions, including IBM, American Megatrends Inc,
Award and Phoenix. CmosPwd will recover the BIOS password for the following
BIOS versions:
password for windows or for bios?
