Acer Extensa 5620 Notebook PC Logo
Question about Acer Extensa 5620 Notebook PC
How to restore acer extensa5220 notebook back to its original set
How do i restore my acer extensa 5200 to its original settings without a recovery disc as i have followed the instructions in the user guide and failed to restore it .simple step by step guides would be appriciated its windows vista.thanks.
Posted by juliesymo on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 52 Answers
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
Roshan Rijal
    An expert that gotĀ 10 achievements.
    Sergeant:
  • 361 Answers
If u like this dated system restore ,u can do this process. chose you before date of changed.star- program acess.-system tool-system restore- change before date-tick on restore my computer then do next .it take few time. thanks
Posted on Jun 12, 2009
How to fromat labtop acer extensa 4620
@sijokmathews
Acer laptops have a built-in recovery mode on the system wherein you can restore the computer to factory default (please note that this will erase everything). The hotkey for the recovery is the ALT+F10 key. After you press the power button, you need to hold ALT and then simultaneously press the F10 key to start system recovery.
Once the recovery menu has loaded, click Restore to Factory Default Settings.
Cheers,
2answers
I need to restore my acer 5610z laptop back to factory settings
To restore my computer to its original settings without
recovery CDs.
Note: If your system is the multilingual version, the operating
system and language you choose when you first turn on the
system will be the only option for future recovery operations.
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press during POST.
37
English
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press + at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 3 to 4 GB in a hidden partition
on your hard disk
Thanks for choosing Fixya
1helpful
Missing !!0xc01a001d!! 28704/98270 (\Registry\Machine\Components\DerivedData...) I can't boot up, need help how to deal with this issue please!
To restore computer to its original settings without
recovery CDs.
Note: To activate the BIOS utility, press <F2> during POST..
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
Important! This feature occupies 15 GB in a hidden partition on
your hard disk
2helpful
Acer Extensa 4620-4605. Hidden hard drive? What is it for and how do I find it?
Welcome and thank you for using fixya.
Hidden harddrive or partition are usually alloted for factory restore software.This software will restore your computer to original factory state without using the recovery disk. In order for you to find if you hve one in your computer. All you need to is to go to computer management then go to disk management. The easiest way to get there is by clicking the start menu then type in under start search or run bar this compmgmt.msc then press enter.
All the best!
How do I factory restore on acer extensa 5420
you will need the recovery disk from acer or you maye be able to correct any problems bye pushing F8 at the start up and select.
the last know settings that worked (advanced)
2helpful
Where can i buy a recovery CD for my Acer Extensa
Important! This feature occupies 10 GB in a hidden partition on
your hard disk.
26helpful
3answers
Acer extensa 4630z windows complete restore
I wrote to Acer myself about this and this is their reply.
If you see this:
3helpful
2answers
I want recovery cd for acer extensa 5620.. please help me any one
u can restore ur computer like this when u dont have Recovery CD for ur Laptop and when ur OS is set then u can make One from Acer E REcovery Software
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
Pls rate me Fixya for help more questions are welcome !
1helpful
Need original manufacturer settings
Hi there.
When you turn the laptop on, I believe you get an ACER logo, press Alt and F10. This should start the recovery program.
If you need any more assistance, just ask, I'll be glad to help.
Tim
1helpful
D2d recovery
Hi there
You want to restore your computer to its original settings without
recovery CDs?
This recovery process helps you restore the C: drive with the original software content that is installed when you purchase your notebook. Follow the steps below to rebuild your C: drive. (Your C: drive will be reformatted and all data will be erased.) It is important to back up all data files before using this option.
1 To activate the BIOS utility, press <F2> during boot up.
2 Check to see if Acer disk-to-disk recovery is enabled or not.
3 Make sure the D2D Recovery setting in Main is Enabled.
4 Exit the BIOS utility and save changes. The system will reboot.
Good luck and Merry Christams
Steve Sweetleaf
Steve Sweetleaf
shadow
